04-19-2007, 11:50 AM | #1 |
Pebble Pounder Join Date: Dec 2006 Location: San Diego
| pti stripping out wheel hexes
are any of you guys having problems with your goliaths stripping out wheel's. i assembled the truck acording to the instructions and tightened the wheel hexes then backed them off so they wouldnt bind, about five minutes later one wheel stripped. i switched out to new rims and the 2 more stripped, is there any fixes for this. -jon |
04-19-2007, 12:37 PM | #2 |
Rock Stacker Join Date: Apr 2007 Location: coeur d alene
i have never had any problems with wheels striping but this could be a good excuse to buy aluminum beadlocks
04-19-2007, 12:41 PM | #3 |
Rock Stacker Join Date: Feb 2006 Location: MN
Try some locktite on them. Let it cure good overnite and you should be set. I haven't had this prob but I do mine whenever I change them. Shaun |
04-19-2007, 01:14 PM | #4 |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
The wheel pins that the PTI comes with are pretty small and have a lot of play in the stock wheels, that's what causes them to strip out. Your best bet to to make some new longer wheel pins. I made some by cutting the head and point off of a nail that was just big enough to fit through the hole in the axle. Seems to work well.
04-19-2007, 01:16 PM | #5 |
So are you still using the stock wheels or are you running wheels with an actual hex? I have yet to have a problem with wheel hexes (knock on wood). If you're still running the stock style wheels with just the pin, don't back off the nut at all... as a matter of fact, if you're using actual hexes don't back the nut off. I don't.
04-19-2007, 01:34 PM | #6 |
| If you don't back off the nut, the wheels bind so bad they will barely turn. Not the solution tho I agree. If you are still going to use the stock wheels, you need to sand down the face of the wheel where the crosspin goes so that it does not press so tightly against the bearing. Then you will be able to tighten the nut fully so that the wheel is tight on the pin.
04-19-2007, 02:20 PM | #7 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
wow, Im running a gd600 with mine and have bound the heck out of the wheels and done no damage. I agree with not backing the nut off, mine are tight!
04-19-2007, 02:27 PM | #8 |
Pebble Pounder Join Date: Feb 2007 Location: Evergreen
Just get some msd beadlocks, and metal hexes *l* I never stripped hexes, but I never ran her stock either, so I have no idea.
04-19-2007, 02:29 PM | #9 |
Jeez... you guys must be a bunch of gorillas! I guess I just don't tighten mine down all that tight |
04-19-2007, 04:18 PM | #10 |
Quarry Creeper Join Date: Oct 2006 Location: kansas city
I have not seen the PTI in person, but I thought it was based on Associated parts. You probably need to move shims from the inside of the axle, and add it on the outside. Could you post a pic of the knuckle and axle, maybe that would help. Later,Randy |
04-20-2007, 01:14 PM | #11 |
there is no room to place a shim between the pin and the hub
06-08-2007, 01:52 AM | #12 |
Rock Crawler Join Date: Apr 2005 Location: Upland
I have a set of Tamiya clamping style aluminum hex adapters and replaced the stock pins with solid ones. I also use RPM revolver rims for the front of the Traxxas Stampede (part #82051) on all four corners. This setup works awesome and can handle the torque (especially if you use a gear reduction). Just to let you know though, those wheels are a narrow off-set, so if you want a wider truck you'll have to use a set of rear Stampete wheels. Or anything else that uses a hex.
06-08-2007, 09:43 AM | #13 |
| The stampede rears would actually give you a more narrow truck, to widen it out you want electric stampede fronts.
06-08-2007, 10:10 AM | #14 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
funny, ive never had that problem either...... oh, wait a minute, i have a tlt, thats why! |
06-08-2007, 10:19 AM | #15 |
06-08-2007, 10:46 AM | #16 |
finally stripped mine, all 4 at the same time. I decided tha I am going to drill them out and throw in a large pin and use the hpi wheels so if I strip again it will only be the hex's not the rims.
06-08-2007, 10:56 AM | #17 |
| You're right, I had that backwards. Sorry about that. But anyway the part number I'm using is correct in my post. I got that from the header card that they came in.
06-08-2007, 10:59 AM | #18 | |
Then you won't have to worry after that. | |
06-08-2007, 11:05 AM | #19 |
06-13-2007, 10:02 AM | #20 | |
Anyways, try some hex drive wheels and make some longer pins out of a small nail or piano wire (much stronger), I CA my Traxxas wheel hexes to the Stampede front wheels and then use a little SHoe Goo to build up the area around the wheel hex...and keep the nuts tight with Loctite! Helps alot. If you're using stock wheels, then as stated use as long a drive pin as possible, shave the backside of the wheel a little so they don't bind the bearings when the wheelnut is nice and tight. If you shave a little too much off the back of the wheel, then a shim will help remove the excess play. | |
