01-27-2008, 07:36 PM | #1 |
Pebble Pounder Join Date: Nov 2006 Location: Heaters, WV
| TLT axles with high lift springs question
Alright, I did do a search, and turned up empty. I am in the process of building my first leaf scaler. I am using TLT axles, and want to use High Lift springs. I am running the axles upside down so I can use the two holes that are in line on the diff case. Question is, can I mount the springs directly to the case, or do I need a mounting block. Also, will stock High Lift blocks work. Any help would be greatly appreciated. Thanks in advance. |
01-27-2008, 08:19 PM | #2 |
Quarry Creeper Join Date: Jun 2006 Location: Pinckney
No need to flip the axle, I just drilled mine right through. I also used a 1/4 in Lift block. link to my build> Scout scaler. yup another one. |
01-27-2008, 09:00 PM | #3 |
RCC Addict Join Date: Jan 2006 Location: The "Hive"
Here ya go, this might help. At least give you some idea's. Those are TLT's with High Lift style "Diaz" leaf springs(2 hole). What frame are you using? |
01-27-2008, 09:11 PM | #4 |
| Thanks
Thanks rock runt. That answered my question. I am running the axles upside down for a reason. I will explain later on. Thanks for the help. I am hoping to get by without spacers. muddauber7, I purchased a prototype Xtrail chassis from The Crawler Store, and used it to pattern a pair of chassis rails. I have sent them out to get them powder coated. I will post some pics when the building begins. I am still waiting for parts, and rounding them up as well. I will keep everyone posted. Thanks for the help. |
01-29-2008, 07:59 AM | #5 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
you can just screw them into the case, no need to use the little block.
01-29-2008, 05:57 PM | #6 |
Yeah, this is what I have come to learn. Now if the dang springs and mounts would just get here. I got my chassis back from powder coating today, looks awesome. Just playing the hurry up and wait game on parts.
