01-10-2007, 01:15 PM | #1 |
RCC Addict Join Date: Jul 2006 Location: Johnston SC
| tech: tranny link mounts
well guys i started rebuilding my scale tlt lastnight after painting it up and figured why not share with you an idea that i used on link setup. now i no many of you use pede trannies in your crawlers, and almost all of you cut off as much as possible because they are huge. well in my rig i used a unmolested pede tranny to my advantage. when i built my scale framed rig i had a hard time deciding on where to mount my upper links to the chassis and then it hit me. what about the stampede rear a-arm mounts. with a little threaded rod and carbon tube it worked perfectly. sorry if im just using an old idea. its just the way mine is setup and i have never seen it done b4. thanks. |
01-10-2007, 01:27 PM | #2 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
i see bent bolts in your future.
01-10-2007, 02:04 PM | #3 |
maybe but its ben bashed and slamed pretty hard and i haven't had any problems.
01-10-2007, 02:10 PM | #4 |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
The only problem I see with that, is I am pretty sure those ears are toed in on one side to give the rear wheels of the pede a slight toe in, so when you mount the tranny sideways, your links will be a little shorter on one side...
01-10-2007, 02:22 PM | #5 |
it doesn't cause any problems the links are all the same length. i just beveled the carbon tube a bit to compensate for it.
01-10-2007, 03:41 PM | #6 |
Pebble Pounder Join Date: Sep 2005 Location: minocqua
if the bolts start to bend, run another link in between the two mounts, that would hold it in place, and keep them from bending.
01-10-2007, 03:46 PM | #7 |
Rock Crawler Join Date: Sep 2004 Location: Knoxville
I ran a tlt that had the lower links running off the pede, I had no problems with it. I think it works out fairly well! |
01-10-2007, 04:45 PM | #8 |
Goat's Nanotube, Grover's Float ST (I think), and AZVader's rig used links mounted to a Pede.
