05-01-2016, 12:03 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Hanford
| Transfer case only, no transmission???
Can you run a hammer 1.47/1 transfer case straight to the motor with no transmission? For my current build this seems to be my only option for the time being, but need input. I know it's possible to connect the two, but I need to know if it's safe for the motor and t-case. The case in mind will be matted to a 35t rc4wd throw away motor, but I can play around with motors since I won't have gearing options. Again, only if it will work.
05-01-2016, 12:17 PM | #2 |
| Re: Transfer case only, no transmission???
Sure it'll work but you're going to want either an 80 turn motor or a small gear reduction unit like HPI used for the crawler king.
05-01-2016, 12:36 PM | #3 |
Quarry Creeper Join Date: Dec 2012 Location: Pioneer, 95666
Yeah, you're going to have to find some type of gear reduction to attach to the motor like the hpi or a planetary, or use an incredibly high turn motor. If you do the math on kv- x -volts and then divide by the transfer case ratio and axle reduction, that should be a start to figure out what turn motor you need
05-01-2016, 12:54 PM | #4 |
That makes perfect sense thanks guys. Plus that gives me gearing options.
Transfer case only, no transmission??? - Similar Threads | ||||
Bulletproofing Yeti transmission and transfer case? | npcaldwell | Axial Yeti | 1 | 11-12-2014 08:19 PM |
transmission into transfer case | vwmopar | Traxxas Crawlers | 3 | 12-12-2013 10:20 AM |
