Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: Installed WPL winch on JJRC Q60
Old 06-29-2020, 12:44 AM   #1
Default Installed WPL winch on JJRC Q60
I couldn't find any information on this subject when I looked. So I figured I'd show some pics. It definitely came out much better then I thought it would. One of the problems that I ran into was the base of the winch slides between the frame rails. It's not exactly center between the rails because of the motor position. This is my first rc build so It took me a while to figure out that the winch requires it's own esc. We also plumbed it for it's own battery. It's very tight in the wiering area as I'm sure you are aware. We add tail lights, metal front bumper, variable metal gear servo, 2 brushed esc, billet t case and 370 motor, metal drive shafts, swapped the axles for metal ring and pinion WPL axles all 3. We have some other little things. But for now that's where we stand. It climbs very well and looks good doing it.
badlogin is offline   Reply With Quote
Old 07-03-2020, 02:29 AM   #2
Default Re: Installed WPL winch on JJRC Q60
These are some of the pics. It took me a while to get them loaded.
Installed WPL winch on JJRC Q60 - Similar Threads
JJRC willys jeep ,will these WPL axles work as replacements? willygee General Crawlers 2 04-22-2019 06:15 PM
Tires for WPL, JJRC, MN-90, MN-45, Willys Jeep and similar Trucks donaldsneffe Tires and Wheels 0 04-05-2019 02:16 AM
WPL/JJRC Gear Pitch Mitch58 Micro Scale Rigs 1 10-26-2018 06:24 PM
Jjrc q60 6x6 1/ 16 scale rc military truck shenlonco Scale Videos! 0 09-19-2018 07:18 PM
