tkruger | 02-25-2007 09:15 PM | I mounted my between the frame rails with the rear third of the pack right over the rear axle. I have the motor over the front axle with a pede tranny as a transfer case in the center. This set up puts slightly more weight over the rear axle. I have found that if I did not do this mine had trouble getting a grip in the rear and spinning the tires on loose dirt when going over some obstacles. Mine is designed more to be a trail truck than a true crawler. It can crawl but it is better at tackling rough terrain such as mud, ruts, logs, etc. |
