Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: K2-3L/S frame mounted steering servo...
Old 05-18-2007, 11:51 AM   #1
Moderator Rule Breaker
eric113's Avatar
Default K2-3L/S frame mounted steering servo...
Ok, I have k2-3L and built it to the spec sheet. My question is who has frame mounted their steering servo ?? My buddy tried it on K2 and said he got really bad bump steer. I asked franky about his and say it work awesome, So what we doing wrong ?
eric113 is offline   Reply With Quote
Old 05-18-2007, 12:20 PM   #2
Post a pic for starters
OIT_TLT is offline   Reply With Quote
Old 05-18-2007, 12:32 PM   #3
eric113's Avatar
I will, But it built to the build sheet, as far the links and I have 60mm shocks.
Old 05-18-2007, 02:50 PM   #4
MODERATOR™
EeePee's Avatar
http://www.quadratec.com/jeep_knowle...article-68.htm
EeePee is offline   Reply With Quote
Old 05-18-2007, 07:28 PM   #5
i did mine too... bumpsteer is being caused by your draglink being at too steep of an angle. try to get it as long and flat as possible. i mounted it with one mounting ear on the underside of the front crossmember and drilled a hole to mount a servo mount post for the other end... it works just fine.
dieselfuel is offline   Reply With Quote
Old 05-18-2007, 08:25 PM   #6
MOCRAWLER's Avatar
do you have a pic?
MOCRAWLER is offline   Reply With Quote
Old 05-18-2007, 09:19 PM   #7
yep.
Old 05-19-2007, 07:02 AM   #8
MOCRAWLER's Avatar
that looks pretty clean.
Old 05-19-2007, 01:18 PM   #9
thanks, the truck is an unorganized mess, but the steering is pretty slick.
