Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: Venture 12mm hex question
Old 12-22-2018, 11:02 AM   #1
Default Venture 12mm hex question
So I upgraded the tires/wheels on my venture and need a little bit wider hex to prevent tire rubbing. I measured the stock hex and it appears to be 6mm wide. I had a random 8mm wide hex laying around and it’s exactly what I need. Unfortunately there is no brand or anything on it so I don’t know exactly what to order.
Any suggestions would be helpful. Thank you.
flat6extreme is offline   Reply With Quote
Old 12-22-2018, 12:24 PM   #2
Default Re: Venture 12mm hex question
Will these work?
https://www.ebay.com/itm/4Pcs-Alloy-...g3g:rk:35:pf:0
JDM74 is offline   Reply With Quote
Old 12-22-2018, 01:35 PM   #3
Look like they should. Thank you
Venture 12mm hex question - Similar Threads
Question about 12mm Losi hex. Big Pitt Tires and Wheels 6 10-13-2010 05:52 AM
Are these 12mm hex? dextermeth Newbie General 3 10-20-2008 06:40 PM
12mm hex question. Stburr91 Tires and Wheels 0 08-23-2008 08:40 AM
