09-09-2008, 01:49 PM | #1 |
Pebble Pounder Join Date: May 2008 Location: alberta
| My new WK project
well i decided that bigger wasnt better so completely scraped my 16inch WK and started from scratch. as it sits now i have a custom frame made from some 1/16" thick scrap metal i found at work (not to sure what it is but its pretty strong) WK axles, WK transmission with custom clocked motor plate, WK shocks, Revo Driveshafts modded a little, Custom 3 link made from a chunk of aluminium and 4/40 allthread with stainless steel tubes covering it for the upper and some spare axial lower links, integy 55t motor and an HS-645MG Steering servo on a customaxle mount. [/IMG] [/IMG] [/IMG] pics kinda suck ill try and get some better ones of the completed thing tonight |
09-09-2008, 02:23 PM | #2 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
I bet those red X's crawl great.... Sounds cool, fix your pix so we can see it.
09-09-2008, 02:43 PM | #3 |
lol yah i was wondering if it was just my computer that wouldnt show them, guess ill have to reload them onto PhotoBucket and try again tonight, thx for lettin me know
09-10-2008, 01:10 PM | #4 |
ok lets try this again |
09-10-2008, 01:17 PM | #5 |
Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
Looks good What is your wheelbase at?
09-10-2008, 01:42 PM | #6 |
Looks like a little too much flex to me.
09-10-2008, 01:55 PM | #7 |
lol wow did i mess up, i just took it out for its first crawl and the motor is on the wrond side so i have severe torque twist and the shocks are fairly weak so that doesnt help things but ill be putting some spacers on the inside of the shocks to limit the flex. Guess ill have to try and flip the tranny or just wait till my axial tranny shows up, oh and the wheelbase is about 13 inches and i also need to replace the front upper link as you can see the amount of flex in the plastic
09-10-2008, 02:34 PM | #8 |
Newbie Join Date: Sep 2007 Location: NY
| Simular but different
Looks good. I hope to debut my new WK based chassis soon. Yours reminds me of mine a bit. I noticed you clocked the motor using the stock plate and rotated the tranny 90 deg. Is the tranny mounted to the bottom cross-member with the 3 stock screw locations only? If so, does it stay put when there is alot of torque? I decided not to rotate the tranny because of this concern. I'm not sure that rotating the motor will effect tourque twist other than transfer it to the other side of the vehicle. Angling the shocks toward the middle of the vehicle increases articulation dramatically. The stock WK shocks are too long for that angle. Your ride height seems pretty high. When climbing does your rear end shoot straight up? I had this problem with my stock chassis and am going to raise the back end of the rear upper links which should prevent the torque at the rear wheels from trying to drive under the truck. |
09-12-2008, 02:15 PM | #9 |
Quarry Creeper Join Date: Jun 2007 Location: Sacramento
Looks good, but I agree, too much flex. You'll soon realize too much flex will just get you stuck on holes etc... LImit the travel and the wheels will "float" over holes instead of dropping inside them.
09-18-2008, 04:46 AM | #10 |
allright so i figured it out, i flipped the axles, reversed the motor so it would now go forward instead of backwards from the axle flip and put about half an inch of fuel tubing inside the shocks to lower it and give it less flex(it has about 80 degrees now instead of 100) and stiffen up the shocks. So now theres almost no torque twist and it sits a little lower lowersing the CG, i was about to scrap it and start fresh but now it runs like a dream, ill try and get a vid up ASAP.
09-19-2008, 12:04 PM | #11 |
allright heres a couple of pics of the finished thing no vid tho the wife didnt want to be the camera man. |
