05-07-2009, 03:49 PM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: Indianapolis Indiana
| will these lockers work with wheely king? opinions?
when i get my wheely king i want to lock the back axle only so will these lockers work? https://www.ssl-stormerhobbies.com/c...=ns&pn=AX30440 or https://www.ssl-stormerhobbies.com/c...ns&pn=HPI88073 also could i balloon the rx, and servo for waterproof in the wk? Could i put press n seal wrap around the esc so it doesnt get wet? will it get to hot? |
05-07-2009, 04:06 PM | #2 | |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
http://www.rcguy.com/Wheely-King-Dif...t-p/me-010.htm You could wrap the servo and rx, but the esc will get hot if it has no air across it. You can keep a eye out for a xl-5 traxass esc. It is as waterproff as it gets. I get mine wet all the time and it is holding up great. Used ones usally run around 40 bucks. | |
05-07-2009, 04:32 PM | #3 |
ok, but those links i posted arnt even direct drops?
05-07-2009, 04:38 PM | #4 |
05-07-2009, 06:59 PM | #5 |
The first one you posted will drop right in just like it does in the Axial...but it's an already weak part since the shaft bores have a bit too much slop to the axle shafts. They eventually start to round out the holes in the locker and fail.
05-08-2009, 12:49 AM | #6 |
Quarry Creeper Join Date: Jun 2007 Location: Mesa, Az
I have the rcguy lockers and they work great. I have been beating on them for years with out any problems. And I've never seen any one bag a servo. All I do is hit the edges with hot glue and put some Vaseline all around the servo horn.
06-26-2009, 09:02 PM | #7 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
can't remember the brand but there is one that looks like an iron cross that is supposed to be good
06-28-2009, 10:42 AM | #8 |
Quarry Creeper Join Date: Jun 2006 Location: um, Houston?
06-28-2009, 11:17 AM | #9 |
Newbie Join Date: Aug 2007 Location: aiea
they work, but just pick up the heavy duty ax10 lockers. much stronger and cheap!
