Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Narrowed WK Axles
Old 12-13-2007, 03:30 PM   #1
Default Narrowed WK Axles
After recently installing a set of MSD RockSolid Top Gun beadlocks (which widen the truck as much as possible), I realized it was time to narrow the WK and make it more crawl-able. I removed about 5/8" from each side, for a total width reduction of about 1 1/4".
First time around I used only CA glue and some strips of plastic to hold the rear case together together, and would have used epoxy had I not assembled the axle (for test-fitting purposes). Then on the front, I used the same method, but used epoxy that time since I knew everything would fit together. A coworker at the LHS was droppin my fully assembled truck when I wasn't there, and I hadn't yet told him that the rear axle was only being held together by CA... it broke. When I got home I removed all of the CA, and then this morning I picked up some fiberglass fabric.
Here's the result, my 3rd attempt:
Please forgive the messiness, this was my first attempt at applying fiberglass, and I didn't vacuum bag it.
That gap in the case is fine, it is very minor and goes away when the two halves are pushed together
Also, since the axles are now narrower, I had to rework my lower links and shocks (the shocks are mounted on the lower links) as the lower links were pushed toward the center. My axle-mounted servo mount also had to be reworked. And that resulted in a BTA steering setup. More on that later in another thread.
MetalMan is offline   Reply With Quote
Old 12-13-2007, 03:37 PM   #2
looks good, but you could have done it this way to, found it on this site:
An idea I came up with to narrow the WK axles.... some may have seen me mention it in slobin3d's thread, I finally got some pics of it.
On the left, stock Wheely King steering knuckle and parts. On the right is Nitro MT 1 parts.
You can see how much difference there is in the length of the axle stubs. What's not as clear in the pic is that the NMT drive cup is quite a bit larger diameter (beefier).
The Wheely King wheel stubs are the same as the REAR of the NMT1. The NMT front stubs are much narrower, and have a larger bearing to get the drive cup inward more.
Here is the stubs with bearings on them:
Part numbers:
HPI A460 - NMT1 steering knuckle/C-hub parts tree
HPI A548 - axle stub
Bearings, one 5x11 and one 10x15 each per knuckle, I use Avid's
NMT2 parts are similar to NMT1 parts, but not sure exactly the difference. I believe the NMT2 comes with CVD axles. The dogbone style drive cups are needed to work with the stock WK axle shafts (86813). The only pdf manual I have for a NMT2 is from the 18SS and it uses CVD's.
In case anyone is interested:
HPI 85076 - NMT2 steering knuckle/C-hub parts tree
NMT hub on the left, WK on the right, you can see the width difference, and height difference:
WK on the left again, NMT on the right, with hex installed:
I'd guess about 3/8" difference in width for each side.
The screws are completely different.
WK on the left, NMT on the right, with the shoulder installed on the screw:
The NMT screws are definitely too short, and the diameter of the collar is too small. The WK screws are much bigger where they screw into the knuckle. Drilling the NMT knuckle and threading in the WK screws should work perfect, but I didn't do so as the NMT parts are going back on the NMT!!
The NMT hubs have plenty of material around the hole, they should hold up just fine after drilling.
bigblazerboy is offline   Reply With Quote
Old 12-13-2007, 04:42 PM   #3
SCALE PERFORMANCE PARTS
Locked Up's Avatar
I'm new to this and all but why narrow it?
Anyway, I think you could have trimmed differently and had the outer housing slip into the center section (at least the top & bottom, the back side would need to be trimmed like you did). Looks like you could have made them slip into the center all the way to the screw posts and I think that would have given you more surface to glue, thus adding some strength.
Don;t worry about the 'glass. Looks better than my jobs
Locked Up is offline   Reply With Quote
Old 12-13-2007, 05:07 PM   #4
Part numbers:
Not seeing any pics.
SpyderMonkee is offline   Reply With Quote
Old 12-13-2007, 05:19 PM   #5
Look in this thread for pics on it:
Wheely King CXT
In all honesty, I don't think that method is the one to go with. At most it will only narrow the width by 3/4", and my truck is now 1.25" narrower than stock, with total width (including M2K tire bulge) at 10.2".
Seems that narrowing it is good . In general people want wheels with less offset for the WK axles than the ones I'm running, so instead I'm running with full offset and narrowed axles. I guess it's supposed to make the truck crawl better .
I'm not sure I understand what you mean by trimming the housing differently.
Old 12-13-2007, 05:24 PM   #6
both ways are good. your way would look better with some cleaning up of the seams, but being 13 option #2 is the easiyest way for me.
Old 12-13-2007, 05:26 PM   #7
o yeah metalman, do you have any pics comparing the stock versus modifyed and what axle shafts are you going to use?
Old 12-13-2007, 05:31 PM   #8
My way could definitely look better if it were cleaned up (I only scraped away fiberglass/epoxy so it wouldn't interfere with anything else), but in all honesty, if I wanted it to look good I wouldn't have done it to a crawler :thumbsup:.
I don't currently have any pics comparing the two (camera battery is charging), but I can get some. I cut down stock shafts and ground the ends to fit into the diffs for the rear, and cut down the CVDs for the front and ground those ends.
Old 12-13-2007, 05:55 PM   #9
cool, looking forward for the pics.
Old 12-13-2007, 07:10 PM   #10
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Yeah, hurry up man....I want to see pics of the finished axles under the truck
Offroader5 is offline   Reply With Quote
Old 12-13-2007, 09:16 PM   #11
JIA's Dad's Avatar
These are the best way to narrow the axle width for most people wanting to narrow a WK axle. See post 147 here
http://www.rccrawler.com/forum/showt...440#post929440
Most guys are not going to cut the axles and housings. So they can get similar results using narrowing wheels. No need to cut anything and no mess.
JIA's Dad is offline   Reply With Quote
Old 12-13-2007, 10:24 PM   #12
That's nice. But what about those of us who just spent $100 on a set of beadlocks . Being in college I'm short on cash (saved up to that $100 for a couple months), but time isn't an issue. All I want to know is why you didn't show me those before I bought my beadlocks .
Old 12-14-2007, 12:28 AM   #13
Locked Up's Avatar
So what I mean is that in looking at each housing half, there are 3 sides (for my demonstration)... top, back & bottom.
So you leave more material than what you cut off the outer housing top & bottom and trim the center a little more on the top and bottom (looking down into it).
I exaggerated the proportions to make the point but sorta like this:
The red parts (the back side) would still be flush, but the dark gray form the outer would slide into the inner light gray, giving you some more to glue to or maybe even slip a bolt into.
Anyway, just my thoughts. I like it wide and that fiberglass will probably be fine.
Old 12-14-2007, 06:40 AM   #14
Offroader5's Avatar
Well, if you'd done some research into what kind of offset the Rock Solids had before you went and bought them, you wouldn't have that problem now would ya....:-P
Old 12-14-2007, 09:21 AM   #15
Ah, I see. That actually looks like it would be a great idea. If my front axle (the one with just plastic and epoxy and no fiberglass) ever gives, I'll do it your way.
Well, the offset on these wheels can actually be a good thing. I've read of rubbing issues with some 2.2 wheels that have an opposite offset to the RockSolid beadlocks, but this way there's no reason for me to worry about that on my truck.
Old 12-14-2007, 09:22 AM   #16
Default COol
Pretty neat way of narrowing these up. Sure beats buying a TLT axle set and blowing another hundred or so into it to beef it up for a scale build.
dynamic_e is offline   Reply With Quote
Old 12-14-2007, 07:25 PM   #17
Natedog's Avatar
MetalMan, cool idea and keep us updated.
Old 02-07-2008, 01:08 AM   #18
Here are the narrowed axles mounted up:
King 4x4 (56K BEWARE)
