12-29-2007, 02:17 PM | #1 |
Rock Crawler Join Date: Oct 2007 Location: richmond, va
| stock esc turing off
when i drive my truck the esc keeps on cutting off. does any one know why, or is it becasue its a little wet out side.
12-29-2007, 02:18 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Either because its wet or its overheating.
12-29-2007, 02:26 PM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
It's because that ESC is for temporary use only. Most generally what likely what is happening is your bogging the truck in snow. This puts more strain on the motor which in turn puts more strain on the ESC. The ESC then trips into overheat mode and shuts off till it cools enough to be used again. The esc is worthless though I tripped mine attemping to crawl after 5 minutes. A new ESC is in order if you want to get rid of the pausing all together. A gearing change (reduction) would help slow things down a bit. A cooling fan also helps. |
12-29-2007, 02:54 PM | #4 |
im not boggin in snow because it doesnt snow much here. i was going through some puddles and i got a new 3300mah batery from radio shack. im thinking about geting a moped esc and usein the hpi one in a cc-01 project im going to do for my dad.
12-29-2007, 02:57 PM | #5 |
Yeah I've found that anything more then wide open driving strains the esc into overheat mode. I tossed mine up on ebay and made $27, went and bought a better esc never looked back. |
12-29-2007, 04:35 PM | #6 |
do you think it is because of the 3300 battery? it doesnt do it with the stock one. im thinkin about getting a moped esc and a square battery from the crawler store, but i dont want an esc that keeps on shutting off, and i dont want to get a new motor or gearing right now, i need to get stuff to extend my wb for my build.
12-29-2007, 04:52 PM | #7 | |
Quarry Creeper Join Date: Nov 2007 Location: Alberta canada
12-29-2007, 04:58 PM | #8 | |
i dont know y but the battery does seem to make it over heat, i dont know y it just does with the 3300 battery instead of the 1500. i think im going to cough up some money and buy a new esc and gears, and parts to extend the wb. | |
12-29-2007, 05:07 PM | #9 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Just get this http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=002 It's what I plan on running in my 2.2. Jeep tuber. And I run 3500 mah packs. |
12-30-2007, 02:32 PM | #10 |
i figured it out. it was the connector of the radio shack battery is kinda loose and comes out of connectiong with the other conection and turns it off, i will just tape it one.
12-30-2007, 07:15 PM | #11 |
Rock Stacker Join Date: Dec 2007 Location: sebastian
it is just going in to (self shut down) because mine did that and i called the hobby store and that is what thay said.
