Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: I know its wrong, but it feels so right!!
Old 04-02-2012, 06:39 AM   #1
Default I know its wrong, but it feels so right!!
I will just post a pic or 2 to get things started:
Just to get things kicked off!
The Real Dogman is offline   Reply With Quote
Old 04-02-2012, 06:49 AM   #2
Default Re: I know its wrong, but if feels so right!!
Looks like a good start.
This for ECC?
bigstu is offline   Reply With Quote
Old 04-02-2012, 06:59 AM   #3
Eh hmm could be grasshopper, could be!
Old 04-02-2012, 07:07 AM   #4
SuperShafty.com
looks great. what wheels are those? 3.3? right?
looks good and fun man.
mjderstine is offline   Reply With Quote
Old 04-02-2012, 07:22 AM   #5
That is "One Sick Ass" WRAITH
That thing is gonna Own The Rocks
Regards Rick
v84x4 is offline   Reply With Quote
Old 04-02-2012, 08:07 AM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Yeah, I dig it!
JohnRobHolmes is offline   Reply With Quote
Old 04-02-2012, 07:28 PM   #7
Killer! Should haul ass
Honchoforever1 is offline   Reply With Quote
Old 04-02-2012, 07:38 PM   #8
When I get home I'm in, took my porker to Florida with me and it is already on the table with the ass end ou of it Less than 5 minutes of chasing kids around. Oh well I knew this thing would be a bitch, stupid inner pinion bearings It will be up and going in another ten!!! Oh yah, looks bad ass
Later,
Farmer
Farmer is offline   Reply With Quote
Old 04-02-2012, 07:45 PM   #9
almost look like it was made for those axles!
2500hdon37s is offline   Reply With Quote
Old 04-02-2012, 09:23 PM   #10
Default Re: I know its wrong, but it feels so right!!
Those are Truggy wheels from my CEN Matrix Arena. And fun is on my horizon!
Regards Rick
Thank you Rick!! Your stuff is my inspiration!! I have not been this amped about a build in a long time!!
Originally Posted by JohnRobHolmes View Post
Yeah, I dig it!
Thanks John! Got anything that might give this beast a boost??
Hope to have it running by next week sometime if I can get the front suspension and steering worked out by then.
Later,
Farmer
thanx Farmer! Hows the Floriduh sunshine working out for ya??
Oh hey, I know a guy that will sell you a set of axles that will hold up to that motor!!
A said the same thing but I was thinking about narrowing the axles and going with the 10.5" wide setup, but wanted to try these wheels on it first, then BAM!!! that its it the stance is locked and loaded!! And all off the shelf parts!!
No real update! but got the driveshaft lengths worked out and cut just waiting on getting the drilled pinions done, mount the elects and get the y-harness made for the 6s setup!! Do I want 22.2vlt 2200mAh or do I want 11.1vlt with 4400mAh??
Or should I make one for each!!??!!?? Wha the hell?? The tranny will take it!! LOL Axles will takes it..
Old 04-04-2012, 02:18 PM   #11
WTF, you are such a tease. What links are under it? Ti SuperShafty links.......I hope. I need to see this thing when I get home. Looks a little wide for what I want, but i know that's fixable These Wraith axles are almost gonna be for sale if my next idea doesn't work.
Later,
Farmer
Old 04-04-2012, 02:46 PM   #12
If you do sell the wraith axles let me know. Might want em if they are not too beat..
You do need these axles with motor.
Old 04-07-2012, 09:52 AM   #13
Bart bender's Avatar
What KV motah you running? I feel sorry for you Mich guys. Having Rick next door is gonna make you all broke as hell
Bart bender is offline   Reply With Quote
Old 04-07-2012, 10:04 AM   #14
Looking awesome Lee!
Ha! He doesn't have to be next door...
chicklet is offline   Reply With Quote
Old 04-07-2012, 11:02 AM   #15
That my friend, is going to be running the Tekin T8 motor on the Tekin R8 esc being fed from a 6s lipo that will 2 y-harness' for more power or longer run time
Thanx britt, it will be a blast to run! And your right even saving on shipping I will still beat the hell out of the PayPal account!
Old 04-07-2012, 01:45 PM   #16
Yes I saw that. What are the specs of that T8 horse? The reason I ask is if the KV is too high, like 1900 or up, 6S will be uncontrollable. 1700kv is even nuts for 6S.
Old 04-07-2012, 06:38 PM   #17
Ah yes, well, it is 1900kv and plan to turn down the throttle curve so I can control it. It is a shame to have this power on tap and not use it all, I do intend on trying!
Small update, got the esc mounted under the hood And the receiver placed. Soldered the wires to the esc and to the motor but will have to cut in the bullet connectors. Drive lines are set With the drilled pinions and the pumpkins on the same side so the shafts are as straight as can be. Rick, the links do clear the shafts with room to spare! got the skid clearanced for the big assed motor. Everything rolls smoothly and true. Can wait to put power to this pig. Waiting on the vp cms kit so I can get the front suspension and steering finished.
That's all for now.
Old 04-07-2012, 07:58 PM   #18
I know someone with some built to the hilt wraith axles for sale Can't wait to see this piglet Maybe with some luck I might have a little piglet for ECC
Later,
Farmer
Old 04-07-2012, 08:51 PM   #19
super shafty tranny?
Old 04-07-2012, 09:23 PM   #20
I'm running the same setup in my BYB (1900KV RX8 On 6S)
And well...........You have seen the video
I had to gear it down at the Pinion to a 17T
And I'm running 3.3:1 Axial Ratio Ring & Pinion
and now am getting 38MPH (much More Controllable)
I cant remember if you have the 4.3:1 or 3.3:1 ring & pinion axial setup
But.....
I will tell you if you have the 4.3:1 R & P setup like "Cordwood" has in his FOFF
Your in for around 53MPH using 6 inch Tires, a 21T pinion and the 56T RR Slipper
Cant wait for ECC
Regards Big Rick
I know its wrong, but it feels so right!! - Similar Threads
So this is how it feels... GraTou Chit Chat 0 01-20-2007 04:00 PM
who else feels this way badtodabone Chit Chat 8 10-25-2005 12:56 PM
Feels like Xmas here! jason Chit Chat 12 03-13-2005 04:05 PM
