Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: Twin Force Torsion Chassis
Old 01-20-2014, 09:17 PM   #1
Default Twin Force Torsion Chassis
Anyone ever seen or know about this torsion chassis? Uses 5/32" rod. Mounts to link mounts on axles.
"Skid" and mocked up at 14"
Szczerba is online now   Reply With Quote
Old 01-21-2014, 09:04 AM   #2
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Default Re: Twin Force Torsion Chassis
It is so cool to see these old parts getting assembled Nice work Shane. Shelby (4xFord) would know the story about this. He purchased it from someone in Germany for the twin force axles. Shelby wanted to use the axles under one of his own builds. The axles had the egressor knuckles that are on the wraith build in this section. The torsion build had a set of custom 3.2" delrin bead locks that were very heavy and have since been sold through C.I. The bead locks were delrin and had removable machined aluminum hexes in both 14 & 17mm.
Nova's Ark is offline   Reply With Quote
Old 01-23-2014, 11:24 AM   #3
Bart bender's Avatar
Old School
Bart bender is offline   Reply With Quote
Old 02-01-2014, 09:15 AM   #4
Originally Posted by Bart bender View Post
Old School
Yes sir.
Rear axle built and rough driveline angle. Mock up stock steering knuckles.
Old 02-01-2014, 11:08 AM   #5
Front axle done.
Some steering clearancing will need to be done.
16" WB
16" WB on 2.2
14"WB will need 5/32" torsion bar trimming
Old 02-01-2014, 12:31 PM   #6
You can decrease your career angle a little too gain clearance.
What is your plan with this? 2.2 unlimited?
Old 02-01-2014, 12:39 PM   #7
I set the caster a little extreme on this setup. A bent steering link and drag link will solve the problem. Different knuckles will be used and Eddie has those or get some. It will be setup as a mini super with narrowed blast wheels and some custom tires that Eddie makes. 2.2s were thrown on just for fun. It's his rig and he will finish it up now. I just built it up with all of the loose twin force axles parts that were left over from the wraith chassis build.
Old 02-01-2014, 02:15 PM   #8
Gotcha
Twin Force Torsion Chassis - Similar Threads
Difference between X-factor, Twin Force and Mad Force axles Flatty XTM Crawler 1 09-11-2008 05:48 PM
Twin Force chassis ? mr.maxx Chit Chat 0 12-14-2006 08:25 PM
