Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: Foxx Differential Bevel Set
Old 08-02-2015, 11:46 AM   #1
Default Foxx Differential Bevel Set
Hi,
Today I started getting slipping in my rear diff, turned out to be a pair of worn Differential Bevel gears.
I've seen picks of spares with 4 inner gears, two notched shafts and 2 outer gears. This would hint at having four inner gears fitted, but mine only has two from factory.
Should I fit 4 inner gears?
Can I buy harder gears?
Should I just buy a standard Kyosho pack with only two inner gears
Thanks for your help.
Rob.
Foxxy is offline   Reply With Quote
Old 08-02-2015, 02:29 PM   #2
Default Re: Foxx Differential Bevel Set
28 people have read this post, but nobody knows about Mad Force/Foxx bevel gears ?
Come on guys !!
Why are there so few replies on this forum and non to me, even on my other post about the Foxx when over 280 people have read it ?
Old 08-02-2015, 03:00 PM   #3
Don't worry, I've just bought two full rebuild kits with 4 inner gears per set and all other parts.
Old 08-02-2015, 03:12 PM   #4
MODERATOR™
EeePee's Avatar
This is a forum, with semi decent traffic and a lot of Google ad bots. It's not Facebook where millions of people and Google bots see your post. Never mind the fact Kyosho trucks are all but dead.
EeePee is offline   Reply With Quote
Old 08-02-2015, 04:25 PM   #5
Aaaah, now I know, thanks for telling me :-)
I always find it funny how a simple question on a forum gets ignored until the poster complains, then everybody comes out the woodwork for a pop! It happens every time.
Nobody wants to help a poster, but everybody Wades in for a keyboard fight!!
Have a good life, I'm out of here :-)
Old 08-02-2015, 04:27 PM   #6
MODERATOR™
EeePee's Avatar
See ya.
Old 08-16-2015, 06:25 AM   #7
soooo,
did u end up with the 2 gears or 4 gears?
Part numbers?
I just got a FOXX and am luvin it!
Just checkin out upgrade b/c u never know!
JOETRUCKER80 is offline   Reply With Quote
Old 08-17-2015, 02:33 AM   #8
You'll need BS107 differential crosspin and IF102 bevel gear set and some kyosho 40.000 diff oil, if you put these in BEFORE you brake anything one set per item is enough for front and rear diffs
CheapTwin is offline   Reply With Quote
