01-05-2013, 01:08 PM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
| RC4WD shocks?? Anybody using them?
So these are just reeeeeally sick looking. Ginger wants me to install a set on Ol' Blue... The problem is there's just not a whole lot of options for spring rates. Well, in fact there are no options at all. Seems like you purchase them and you get what you get. As pretty as they are, they'd be bloody worthless if they didn't hold Ol' Blue up properly and I couldn't put heavier rate springs in to compensate. I don't think I could put her on much of a diet, she's already pretty light for a G.I. Joe Jeep at a little over 9 lbs. Anybody running these, or the plain blue/silver dual-spring shocks which seem to be very similar? BigSki you had the dual-spring shocks on the orange Jeep right? There almost seems like there could be an aftermarket for springs. I mean, you can't just throw this same setup on a 6 lb. truck or a 9 lb. truck, they'll behave completely different. The light truck may be over-sprung and never even use 1/3rd of the total travel, the heavier truck would be under-sprung and sitting on the bump stops at rest. You have to tune suspension, and adjusting spring rates is one of the most important factors... Last edited by Big Mike; 01-05-2013 at 01:16 PM. |
01-05-2013, 03:22 PM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Fairbanks, AK
| Re: RC4WD shocks?? Anybody using them?
I run them on a 9+ lb rig and they seem to work great. I run a few drops of 20wt oil in them to keep them from getting sticky. There is not much for rebuild/compression dampening though. I'm told that the springs are the same diameter as Axial SCX springs, so you do have some tuning options. The stock ones work well for my application. |
01-05-2013, 04:37 PM | #3 | |
| Re: RC4WD shocks?? Anybody using them? Quote:
When I got the shocks I had to remove one of the o-rings and make a spacer to fill in the extra void because the shocks were too sticky to move smoothly. | |
01-05-2013, 04:44 PM | #4 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: RC4WD shocks?? Anybody using them? i agree.. they are nice man! DAYUM!!!! I thought my ax10 weighing in at 6lbs 4.8oz was a lot!!!!!! |
01-05-2013, 04:57 PM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: Lyons, MI
I bought a set of the non piggy back kings and i was seriously disapointed. Ass bada$$ as they look they dont function worth a damn, there not really shocks at all just really cool looking coil springs. Hats off to rc4wd for there awesome products but you'd think for that kind of money they could throw an o-ring and some shock oil in there. |
01-05-2013, 05:57 PM | #6 | ||
I guess some Powerstrokes would probably be a better deal. They look almost as nice, they actually hold oil and do the work a shock is supposed to do, and they're 20 bucks or so cheaper to boot... | ||
01-05-2013, 06:37 PM | #7 |
Rock Crawler Join Date: Jan 2011 Location: Hartford City, Indiana
Big Mike, This is what's going on my GI Joe Jeep when I get it built. I just bought a set for my 1.9 TJ scaler and they are the cat's meow Oil reservoir actually works and adjustible without changing oil or springs. You can also go the oil and spring route and have even more adjustability. Double o-ring shaft seals. |
01-05-2013, 07:46 PM | #8 |
I have a set of the g-made XD diaphram shocks on my 1/6th f250 they hold it up very well. I did swap out the stock springs that came with them for some old traxxas springs cause it weighs over 21lbs and its not finished yet but for under $30 you just cant beat it I'll be buying up a couple more sets for all my other rigs |
01-08-2013, 08:43 AM | #9 |
The G-Made XD's actually look pretty interesting now. They're actually tunable via a little valve inside? They do look nice that's for sure... |
01-08-2013, 09:07 AM | #10 |
Mike, You get three different pistons with them, (2, 3, & 4hole) and there is an adjustment screw at the bottom of the remote reservoir. The screw adjusts the pressure, not the travel.
01-09-2013, 07:16 AM | #11 |
It looks like the screw takes up space in the piggyback, which I assume is going to increase volume in the body and give you some extra tunability. These piggybacks actually function! And sounds like the slightly bigger diameter will make finding stiffer springs easier if needed. To top it off, they're cheaper! These look like the ticket... Thanks for the input guys |
