Go Back   RCCrawler Forums > Vendors > Locked Up RC
Thread: 2.2 Wheel Wideners!
Old 12-05-2014, 02:24 PM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default 2.2 Wheel Wideners!
A lot of you contacted us about having these made so we are thrilled to now offer them!
Our 2.2 Wheel wideners are sold in pairs and will allow you to add just over 7mm to the face of your 2.2 Wheels. The wideners will work with any LURC 2.2 wheel (even the older non Easy Mount® styles) and any 2.2 wheel based on the Axial 2.2 AX10 bead lock ring pattern.
To make use of the wideners you will need to run M2x14 screws or scale hex bolts.
These can be used on the outside or inside (clearance depending) of your wheels or you can also stack these and run M2x21 screws!
Thanks for reading!
Locked Up is offline   Reply With Quote
Old 04-24-2015, 04:29 PM   #2
Default Re: 2.2 Wheel Wideners!
Will these rings work with Raceline Monster 2.2 or Dick Cepek Gun Metal 7 2.2?
mjassbong is offline   Reply With Quote
Old 04-24-2015, 05:48 PM   #3
so would these ring allow us to use the out of scale tires like what the stampede and other types of trucks use?
roughneck is offline   Reply With Quote
Old 04-28-2015, 03:32 PM   #4
Locked Up's Avatar
These are only going to work with wheels/rings that use the Locked Up & Axial AX10 2.2 beadlock hole pattern. There are designs out there but we do not have data on every other manufacturers wheels & rings. My suggestion would be to ask the individual manufacturers if their wheels and rings are interchangeable with the Axial AX10 stuff.
Old 04-28-2015, 03:34 PM   #5
Locked Up's Avatar
I'm not sure what size the bead is on those and do not have any here to test.
I thought Pede tires were a larger bead?
Old 04-28-2015, 05:21 PM   #6
Correct they are 2.8 wheels, stadium trucks run pretty wide 2.2s though.
MattTheGenus is offline   Reply With Quote
Old 04-29-2015, 09:07 AM   #7
Locked Up's Avatar
Thanks for the info.
Roughneck,
These would definitely NOT work on a 2.8" bead.
I've never mounted a stadium truck tire to our wheels but if the bead itself is similar to a typical crawler tire that might work just fine.
If someone wants to try that, let me know,
Old 04-29-2015, 12:13 PM   #8
ok thanks
2.2 Wheel Wideners! - Similar Threads
Wheel wideners / wheel adapters? AXLE 69 Tamiya Txt-1 and Juggernaut 1 03-16-2009 09:22 AM
You may edit your posts
