01-11-2010, 05:33 PM | #1 |
Rock Stacker Join Date: Nov 2007 Location: Arvada
| Mirco Baja Bug ... Chassis ... and hop ups.
This is my Micro that I have been working on for a couple of weeks. 1. Home Made Bug Body 2. Hand cut chassis and skid-plate 3. New Links (bottom links have antenna tubing for spacers) 4. Hi-tec Servo 5. Simmed the lower link potions with nylon washers 6. Widened with nylon washers 7. Wheel base lengthened to approx 5" 8. Battery relocated 9. ESC shrink wrapped 10. Double stock foam in the rear tires 11. Weight added to the front with memory foam 12. Rubber band on the rear springs for damping 13. shock relocated 14. cross braces with all threat and antenna tubing |
01-11-2010, 05:36 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
So artistic with the pictures. I like that chassis and the inboard lower links are a plus! |
