01-11-2010, 06:39 PM | #1 |
Rock Crawler Join Date: Jul 2009 Location: waterville
| anybody else's going 3 wheeldrive
hey. so i've put lots of wear and tear on my mrc lately. just started going 3 wheel drive on me the other day. i took the axle apart thinking i was gonna find a chewed out axle shaft. to my surprise nothing broke.no wear at all. these things are actually pretty darn tough. i know what the problem is was just curious if any one else was having this issue. losi put rubber o rings in the axle stubs to prevent the shafts from sliding out. theres one per stub. they should have put two in there, cause one isnt cutting it. needless to say its a bit of a pain when your crawling and you axle shaft pushes out of the dif. then creating 3wd. i have yet to find anything kickin around to tempararly fix the problem. its an easy fix anyways. so...how bout it. anyone else having these issues? or am i the only one? i still love mine though. |
01-14-2010, 06:43 PM | #2 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
yep, i had the same problem. best FREE fix i came up with is this. take little a piece of aluminum foil, ball it up and stuff it into the stub...put a little in, re-assemble and check. i have not had the problem since....did i mention it's FREE!!!!! hope this helps..cheers! |
