New Build - Micro Rock Racer Here is the tube chassis for my new Micro Crawler build. Started with a plan and designed as I built. It took a long time but I really like how it turned out! Not much to say just .125 styrene tube, super glue and paint. Also has a i.d. retractor winch relocated in the door area. More to come soon. http://i67.photobucket.com/albums/h3...111024x768.jpg http://i67.photobucket.com/albums/h3...141024x768.jpg http://i67.photobucket.com/albums/h3...171024x768.jpg http://i67.photobucket.com/albums/h3...181024x768.jpg http://i67.photobucket.com/albums/h3...201024x768.jpg http://i67.photobucket.com/albums/h3...221024x768.jpg http://i67.photobucket.com/albums/h3...251024x768.jpg http://i67.photobucket.com/albums/h3...261024x768.jpg |
I'm in love. |
WOW thats some time n work keep it coming |
Wow man, that's some serious craftmanship! |
man that look's awesome you should sell them :P |
Looks great, nice craftsmanship and design! Question... how strong are the styrene and super glue joints. Will they hold up to tumbles on these small rigs? If so, I might just have to give one a try! |
Awesome work, Really want to see it finished. "thumbsup" |
thats cool, I want to see it done, what electronics you goin to use same stock gear or goin other way? nice !!!"thumbsup" |
thats the cats @$$ right there! very nicely done. cant wait to see this come together. "thumbsup" |
sweet |
i cant help but worry about the strength of the 1/8th styrene and super glue get it built run it off some ledges, tumble down some steep inclines and if its still in good shape then i love it "thumbsup"...even if it doesnt hold up it looks good now |
I have to say it looks great. I did make one very similar about a year ago but scratched the project because after every small tumble I would have to reglue several pieces. And this type of design makes it hard to tuck in a good battery |
BB II motor Hitec HS-65 TP 7.4V 350mah lipo Custom shocks Quote:
Alot of things determine how strong the chassis is. Design - enough bracing in the right spots. Length of peices - too short or too long can stress the joints. Fit of the joint - I use a Dremel bit to fishmouth the end of the rods. Glue - use quality CA on the ends and then a bead around the outer edge. I made a change to 1 area after I had done the final gluing of it and I could'nt remove the peice with pliers, I had to cut it and then bend it and the styrene broke about 1mm from the glue joint and I had to use the X-acto to cut it off. |
Speaking of 1:1 buggies check this out! I can't think of anything off-road that looks more fun to drive. http://i67.photobucket.com/albums/h3...ockRacer38.jpg |
i quit runnin dp chasis's cuz they couldnt take a fall. if you have to explain why it "should be" strong then its prob not it looks nice though it would make a nice shelf rig |
Thats a very cool set of tubes, can't wait to see more. |
wow that thing looks tough, nice work |
subscribed "thumbsup" |
if this breaks, you glue it back together. and it still looks better than your "it just got stepped on" bug:flipoff: ZIng! I actually like that top |
