01-16-2011, 08:53 PM | #1 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
| Stock wheels/tires - Widetracked and Modded
So i made up another set of pizza cutter tires and took pics as requested this time. Also wide tracked the stock rims. Heres to cutting up a bunch of new parts Cut here. To get these. Then flip the inside to the outside and CA back in place. Onto the tires. Stock vs. Pizza. |
01-16-2011, 09:53 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: Reno
SICK! Nicely done. How's the sidehillin' |
01-16-2011, 10:06 PM | #3 |
Nobody goes where i go, ill just say that |
01-16-2011, 10:21 PM | #4 |
Pebble Pounder Join Date: Jun 2009 Location: edgerton
huh now i got more ideas in my head thats good stuff. cutting the rim doesnt bother me do the tires hold together ive never tried
01-16-2011, 10:28 PM | #5 |
01-17-2011, 08:22 AM | #6 |
Tires hold together good, ive got probably 45 minutes to an hour on the set thats on my truck now. And they were just old used tires that i experimented with.
01-17-2011, 02:27 PM | #7 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Ive been wanting to do that to the tires for a while! great to see it laid out so i dont mess up a set Last edited by spoo76; 01-17-2011 at 02:31 PM. |
01-17-2011, 07:59 PM | #8 |
Newbie Join Date: Aug 2010 Location: eldorado
Ok now I have finished the wheel mod and like the looks I looks more like my real pickup now but now how did u glue the inside of the tires back on did u just eleminate the beed lock ring and just glue it to the bead that's now on the inside of the wheel and do the outside the same as normal
01-17-2011, 08:34 PM | #9 |
After you make the tire taller, you dont have to do anything other then slap the new sidewall on the outside of it.
01-17-2011, 09:39 PM | #10 |
Well I'm not doin the tire mod that is just not for me but i think I got it figured out no biggy
01-18-2011, 07:54 AM | #11 |
Ooh, i misunderstand what you were asking. The inside bead (on the rim) is now backwards, compared to stock. So now the tire bead stays in the inside of the lip, instead of sitting on the outside like stock. Better ? |
01-18-2011, 10:24 AM | #12 |
I think I figured out what to im gonna cut the outer bead off too and remove about half the center lip and the flip the putter bead and glue it back then drill all the screw holes through so I can use them as real bead locks and it will narrow the wheel and help give more contact area to the ground
01-18-2011, 02:12 PM | #13 |
Rock Stacker Join Date: Nov 2006 Location: 1/2 way between Cleveland and Columbus
01-18-2011, 03:14 PM | #14 |
01-18-2011, 07:12 PM | #15 |
| Was talking about air hockey. Tires look good. How is your run time affected?
01-18-2011, 09:44 PM | #16 |
