01-31-2012, 12:40 AM | #1 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
| aluminum links
so i picked up some losi mini t ball cups and 1/8" aluminum tubing to make custom likes (i was told that 1/8" works) is the tubing suppose to go inside or outside the ball cups? if neither, then what? thanks!
01-31-2012, 07:51 PM | #2 | |
Rock Stacker Join Date: Jan 2009 Location: Calgary
| Re: aluminum links Quote:
Hope that helps. If you look for my build you'll see the links with the tubing over the rod. If you look at "Rik"'s build he didn't use the tubing so you can see the rod i'm talking about. I like the look of the tubing but if I was to do it again I might just leave them bare, it was a bunch of extra work. | |
01-31-2012, 08:07 PM | #3 |
| Re: aluminum links
Damn! I was hoping I didn't have to order some :( neither my lhs not my local home depot carry the right size :(
01-31-2012, 08:25 PM | #4 |
Rock Crawler Join Date: Oct 2011 Location: minot
| Re: aluminum links
I think its 2/56 rod... Any shop that does helis or planes should have it. |
01-31-2012, 09:22 PM | #5 |
| Re: aluminum links
I'll double check hobby town again
01-31-2012, 10:48 PM | #6 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
| Re: aluminum links
2 mm threaded rod would work great and be stout. You'd have to heat the rod to thread it it in though.
01-31-2012, 11:57 PM | #7 |
| Re: aluminum links
like i said ill double check hobby town again. i dont recall seeing any allthread there but at home depot they had nothing close to that small
02-03-2012, 04:10 PM | #8 |
| Re: aluminum links
ok got the all thread now whats the trick? these are pissing me off the the MAX!!!
02-03-2012, 04:16 PM | #9 |
Rock Stacker Join Date: Aug 2011 Location: canada
| Re: aluminum links
what size did you get? i use a thread tap to run into the link ends so the rod turns into the ends easier. just measure what you need and use dremel to cut rod to size. bevel the ends and thread em in. |
02-03-2012, 04:26 PM | #10 |
| Re: aluminum links
i got 2/56 and n00b question whats a tap?
02-03-2012, 04:31 PM | #11 |
| Re: aluminum links
A tap is a tool to thread the ball cups to make the job cake. A 2/56 tap would allow easy install, but not necessary. It helps me to bevel the ends of the rod, hold them with locking pliers and thread the ends on.
02-03-2012, 04:53 PM | #12 |
| Re: aluminum links
I tried just screwing them on and it won't work
02-03-2012, 05:00 PM | #13 |
Quarry Creeper Join Date: Sep 2005 Location: Canon City
| Re: aluminum links
Heres a few pics that may (or may not help) That is 2/56 rod, with 1/8th tubing over it. It took a little bit to get it started and then went O.K. |
02-03-2012, 05:05 PM | #14 |
| Re: aluminum links
I cut them and bent them I just can't get the damn cups on and thanks for the pics
02-03-2012, 05:12 PM | #15 |
| Re: aluminum links
first things first. drill a hole JUST big enough through the cup to access the ball stud with the .05 wrench. THEN cut 5mm off the end of the cup. i believe the measurement from ctr of the cup to the end is really close to 9mm. that is the effective length. (9+9+your length of aluminium tubning will be your link length) cut your outter tubing to the lengths u require. if u are doing rear bent links add 5mm to it. then slide the rod through the tubing leaving about 4/5mm out each end of excess to thread into the ballend. use a file to give a "point" to the rod (u just want to have a decent thread to start with that is small enough to go into the cup. rubbing the rod on a candle or a bar of soap just at the tip can help lube the rod to tap easier. should look close to these |
02-03-2012, 05:14 PM | #16 |
| Re: aluminum links
if there are burrs on the end of the cut rod it wont go on right. bevel it. hold rod at an angle and spin it on the running cut off blade. make it kinda like cone shaped at the end of the rod. careful of fingers.
02-03-2012, 05:14 PM | #17 |
| Re: aluminum links
haha bloodbane beat me to it! i was taking a pic! he didnt cut his ballends so his effective aluminum tubing length is shorter. |
02-04-2012, 03:15 PM | #18 |
Pebble Pounder Join Date: Jan 2010 Location: Roswell
| Re: aluminum links
I use an x-acto to remove a little material from the opening of the ball cup to make threading easier.
02-04-2012, 04:01 PM | #19 |
| Re: aluminum links
sooo .... how'd it go .... or didnt it?
02-08-2012, 11:48 PM | #20 |
| Re: aluminum links
i have came to the conclusion that i am incapable of creating my own links so i will resort to paying someone lol i can even send you the materials (except for the ball cups i wrecked too many of them lol) here the dimensions i need Upper Front: 5 cm middle of ball to middle of ball Upper Rear: 5.5 cm middle of ball to middle of ball I want the lower to be bent at about 30 degrees so the dimensions of those will be based off of the upper links please pm me thanks guys |
aluminum links - Similar Threads | ||||
aluminum links!!!??? | That Jeep Guy XJMJ | Axial SCX-10 | 16 | 09-09-2011 10:26 PM |
aluminum links | scx10basher | Axial SCX-10 | 3 | 08-07-2011 02:08 AM |
Aluminum links | rockcrawlerman | Axial AX-10 Scorpion | 4 | 03-05-2011 11:01 PM |
aluminum links for TR | ebbet | Axial SCX-10 | 2 | 11-18-2009 07:51 PM |
Aluminum links | CarterFab | Losi Mini-Rock Crawler | 4 | 12-14-2008 11:03 PM |
