Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: No more beadlock wheels available?
Old 03-13-2015, 03:19 PM   #1
Default No more beadlock wheels available?
Anybody know where i can find some beadlock wheels? It seems these little 1/24 crawlers and parts are becoming nonexistent. I've ordered myself a Redcat Sumo Crawler as I can't find a Losi Micro Crawler and Trekker doesn't look much for modding and crawling. Also ordered some Miclaws but now i can't find beadlock wheels. I'm assuming any wheel i find for the Losi micro crawlers/trekker will also work on the sumo. BWD doesn't seem to carry the vertex beadlocks anymore and RC4WD beadlocks are also out of stock. Am i 5 years late to the party? Guess i'll be gluing miclaws to the stock wheel and modifying it to be wider. Back in the day i made my own little 1/36 crawler but these little guys look like a lot of small fun and i've seen some Sumos tricked out that are pretty capable crawlers.
bchamble is offline   Reply With Quote
Old 03-13-2015, 03:28 PM   #2
Default Re: No more beadlock wheels available?
The trekker is basically the same truck with the same parts as the micro crawler. A different and longer chassis, longer driveshafts and links, wider axle shafts with thicker wheel hexes in the same axle housing. Motor and electronics are the same. For what its worth the HSP 1/24 crawler seems to have most of the parts interchangeable with the sumo crawler which in turn makes them compatible with the losi. In particular the drive shafts and wheel hexes. As far as wheels there are a few threads on that on the first page of either the micro scale or micro losi page. Some are 3d printed,others are resin cast
spoo76 is offline   Reply With Quote
Old 03-13-2015, 05:01 PM   #3
For a true Beadlock, check DANALLY, he make some good stuff Good Luck and welcome
complete wheels and tires list!
MikeChino is offline   Reply With Quote
Old 03-13-2015, 05:19 PM   #4
Dans rims, you want these. ;)
http://www.rccrawler.com/forum/vendo...ead-locks.html
This was made from a Trekker... ;)
Fungi is offline   Reply With Quote
No more beadlock wheels available? - Similar Threads
Beadlock vs non beadlock wheels Kocis715 Tires and Wheels 0 05-19-2012 05:16 PM
