Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Pinion's in the box?
Old 11-29-2009, 07:16 PM   #1
Who's your Daddy-0!
Default Pinion's in the box?
How many of you have changed the pinion on your rig yet? I just found the other 2 pinions in the box today, I didn't know they were in there! I'm going to try out the 14t and see if that will get rid of some of the stall. Not sure what size pinion is on there now?
TattooKenny is offline   Reply With Quote
Old 11-29-2009, 07:21 PM   #2
Comes stock with a 10 tooth pinion, I counted while I had mine apart. Should've counted the spur too, but I didnt.
getbent is offline   Reply With Quote
Old 11-29-2009, 07:26 PM   #3
Who's your Daddy-0!
Thanks. Well no use in changing the pinion then The 14T will just make it worse!
Old 11-29-2009, 09:59 PM   #4
can you get anything smaller than a 10t?
I would assume there are the same pitch as the micro t stuff?
I would love to have the option to start slower.
username is offline   Reply With Quote
Old 11-29-2009, 11:59 PM   #5
Who's your Daddy-0!
I don't know? They are push on pinions with no set screw. I would guess that if they do make them that they wouldn't go much below a 10t? A 7t would be awesome!
I think a good motor and a 2s lipo will wake this little guy up! I'm going to drop a Mamba Micro 8000KV brushless in mine tonight with a Mamba 25 and see what happens!
With the other pinions that come with the kit I can't imagine why there in there though? It stalls pretty easy with the 10T pinion, a 14T would be way worse and the other one (I haven't counted the teeth on that one yet) I would guess prob wouldn't even move this rig!
Old 11-30-2009, 08:21 AM   #6
Comes with the 10T on it, the other 2 are 12T and 14T.
ScalerLover is offline   Reply With Quote
Old 06-20-2017, 10:43 AM   #7
Default Re: Pinion's in the box?
Here's a newb question. I just received 2 new brass pinions for my micro. I'm wondering what kind of glue I need to use to install it. The old plastic pinions were stripped and would spin on the motor shaft.
SiFtoN is offline   Reply With Quote
Old 11-29-2017, 11:17 AM   #8
From what I have read/viewed you will need to heat the pinion with a lighter to get in on the output. I have also read that you can press them on while supporting the output with pliers etc. Youtube
doubler is offline   Reply With Quote
Old 11-29-2017, 01:02 PM   #9
There are 9T pinions available online in brass
cleanandserenesteve is offline   Reply With Quote
