Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Leave transmission dry or ad lube?
Old 03-09-2009, 01:45 PM   #1
Default Leave transmission dry or ad lube?
I pulled apart my transmission today to track down some weird gear lash sounds I'm hearing and discovered that unlike the diffs, there is no lube in the tranns. Anybody know why that is?
The gears were solid, so I went ahead and added some white lithium grease and closed it back up. Was that a mistake, should I have left it dry?
dave m is offline   Reply With Quote
Old 03-09-2009, 01:52 PM   #2
i dont see why not, i greased mine and it didnt seem to hurt anything, it did quiet it down a little. i say you're good
up-n'-ova is offline   Reply With Quote
Old 03-09-2009, 02:46 PM   #3
Might have to try it myself, using a push on mini t gear helped quiet mine down some.(on a trinity motor with splines on the shaft)
Failedabortion is offline   Reply With Quote
Old 03-09-2009, 03:01 PM   #4
cool, I cant see why it would be a problem... but if thats the case then why didn't Losi lube it? oh well, i did it so guess
i'll see if makes a difference.
Old 03-09-2009, 04:13 PM   #5
I run min with white lithium grease. I did it out of a force of habit. Yes they don't come with grease, but I cannot run a trans without it. It is quieter and smooth I will attest to that.
O.C.D. is offline   Reply With Quote
Old 03-09-2009, 04:40 PM   #6
Another good option is some shock oil. I started doing that when i used to race because it was alot thinner and smoother than the grease they give you. You only need a small amount. And for little cars like the mrc the less resistance makes it that much easier on the motor
racer22 is offline   Reply With Quote
Old 11-20-2016, 09:31 AM   #7
Default Re: Leave transmission dry or ad lube?
Lucas red n tacky 2 just a little bit works great
Brinkman804 is offline   Reply With Quote
