09-18-2009, 03:06 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: Northern
| Are losi CVD's junk?
anyone snap their losi CVD's? I had installed a set and not even a full battery, one snapped at the knuckle. Rig wasn't in a tight spot, wasn't even turning and barely on the throttle. |
09-18-2009, 03:20 PM | #2 |
Sr. Product Developer Join Date: May 2005 Location: Fontana
Yes and no. Normally no, but we did have some bad ones sneak through. I have put a block on all those that we had in stock including the replacement stub axles itself. I'm currently working with our vendor to get corrected parts and at that time I will be able to replace those that broke but please hang on to your broken parts. I'm not sure how soon I will have replacements ready but once we do I'll let our customer service department know and we'll post info here and on the Losi forum. Sorry for the hassle, Rich |
09-18-2009, 09:48 PM | #3 |
Newbie Join Date: Sep 2009 Location: Boulder
| Refreshingly honest answer Rich
Rich: Thanks for the refreshingly honest answer. That's the way smart companies build loyalty. Is there a way to tell which CVs are from the bad lot, before they break? Thanks, Chris |
09-18-2009, 10:43 PM | #4 |
Quarry Creeper Join Date: Feb 2009 Location: Glendale Az
been beating the crap out of mine for about a year at comps and playing around............gone through a couple of new motors , gear swaps and tires with zero issues..even ate up an aluminum locker......no problems
09-18-2009, 11:05 PM | #5 | |
Rich | |
09-19-2009, 08:19 AM | #6 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
Fawk. I threw mine away. Two pairs. What about receipts. . Well mine broke the same way as pic, but also cracked the ball on the shaft. I was having pin/binding issues. First I lost a pin, replaced it quickly not thinking to check things out. W/ the new pin installed still 3wd. Threw it in the truck and tore it down later to find the shaft broken from ball and cracked inner shaft
09-19-2009, 08:24 AM | #7 |
Rich, I Appreciate the quick response and your efforts in rectifying the problem concerned with Losi's products. I hope my topic heading didn't disturb you, the Losi staff or anyone insterested in purchasing losi products. thanks, Justin |
09-20-2009, 10:32 AM | #8 |
Newbie Join Date: Apr 2009 Location: Orange County
I got a set of those which Rich is talking about... I sheared one off 5 minutes into my first run with them installed. I now have the broken parts on my carnage wall... bring on the replacements LOSI |
09-20-2009, 09:01 PM | #9 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
| Not to hijack but...I've running the factory dog bones for almost a year with zero problems there are ways to get the same steering without cvd's which there are several complaints about....but I give props to Rich and Losi for trying to fix what is bad and doing it as fast as they can. Put you dog bones back in and keep on crawlin |
09-21-2009, 08:03 AM | #10 |
Rock Crawler Join Date: Sep 2008 Location: Nashua,NH
2nd on running the stock dog bones. I have been running the stock bones from 1st day and havent had any problems.
09-21-2009, 08:48 AM | #11 |
I'd like to see close-ups of how you get them to turn as sharp as CVD's
09-21-2009, 09:46 AM | #12 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
Losu treated me nicely thanks Rich
09-21-2009, 01:16 PM | #13 |
09-22-2009, 07:09 PM | #14 | |
09-22-2009, 08:20 PM | #15 |
My bad for not getting here earlier. Stock dog bones modified |
09-23-2009, 08:18 AM | #16 |
So you cut about 1/4" off the axle shaft? Doesn't that want to seperate from the dogbone? Furthermore, did you cut any of the dogbone "tabs" off because with my MRC at full steer, the dogbone hits the inside of the axle shaft.
09-23-2009, 09:37 AM | #17 |
The only thing you nedd to do is cut the dog bone about half way, then rebevel. . On these I cut a little too much, I know it's hard to see but that's why I didn't rebevel these. With the tires pointed straight mark the dog bones so there's still enough bite for them to grab when driving straight. Leave yourself some room so you can rebevel. Now you'll hit the housing during full steer rather than your dog bones maxxing out. I knew about this for a while. But didn't bother until Gatekeeper and Trace showed up and kicked my ars. |
09-24-2009, 06:14 AM | #18 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
I am running mine exactly like Sneed is, and have had zero problems with it no matter how hard I abuse it. Works great and wont break... best of all ITS FREE |
09-24-2009, 06:54 AM | #19 |
09-25-2009, 06:45 AM | #20 |
And for extra bonus points, clearnce the housing and "C's" with a small hand file or dremel so you can get some really crazy throw
