09-19-2010, 02:38 AM | #1 |
Newbie Join Date: Sep 2010 Location: Leeds, UK
| got our MRC yesterday....I discovered 2 things....
...it's bloody addictive and my wife does not like 'rockerys' appearing in our garden without prior planning permission My son (6) and I (43 going on 6) are new to RC and we like building kits etc together so next weekend we will start the following basic mods:
Probably later on we will look at chassis kits etc. A couple of questions though: to reposition the battery is it necessary to lengthen the wire? or should the ESC be moved so you don't have to (where to?) Also - limiting the articulation - do you normally tweak that on front and rear? Are there any other quick/cheap/free mods to limit torque twist? Cheers, Rich (and Dominic) |
09-19-2010, 01:47 PM | #2 | ||
Quarry Creeper Join Date: Apr 2009 Location: Hampshire, UK
Hi Rich, Good to see another UK 1.9 runner, good crawling near Leeds from what I remember. I want to get up there again soon to crawl. Anyhow, Soundcolors' sticky gives great new user info - Quote:
Let us know how you get on and post pics. | ||
09-28-2010, 07:50 AM | #3 | |
RCC Addict Join Date: May 2010 Location: Los Altos, California
2. The articulation stock is crazy stupid!! Limit it by adding a 1/4inch long nitro fuel tubing inside the shock. 3. No mods to really help with torque twist.. But you can try stiffining out the rear left shock and also add heavier weight oil to reduce the amount of TT.. helped me alot when I had the stock chasis. | |
09-28-2010, 10:22 AM | #4 |
Rich. 4 link plate and bent delrin lowers along with a front link plate on there way to you This should help a little. Cheers, Neil |
09-28-2010, 04:42 PM | #5 | |
also a better chasis= better crawler.. my stock MRC couldnt crawl this 1 section, but dropped in a GC-3 and it managed to crawl and stay with the 2.2's! | |
06-04-2012, 01:58 AM | #6 |
Newbie Join Date: May 2012 Location: Derbyshire, uk
| Re: got our MRC yesterday....I discovered 2 things....
Sorry to hijack your thread, but I am also looking to reduce torque twist and limit articulation. My question- is there a 4 link 'kit' available? I'm struggling to find much in the way of mrc hop up parts here in the UK. Any help would be greatly appreciated. |
06-04-2012, 10:21 AM | #7 |
Pebble Pounder Join Date: Apr 2012 Location: sa
For a four link kit you can get the mrcpro servo mounts they have the places to bolt the links for. You would need to either make some links or find some similar in length. not sure the size so dont want to point you in the wrong direction. You could stiffen the left rear shock to help with TT but, until you get 4Link you pretty much have to live with it. |
06-04-2012, 01:08 PM | #8 |
Quarry Creeper Join Date: Jul 2011 Location: Hemet
2 limit the travel...take apart the shoks and unscrew the joint from the piston...add more plastic o rings...hard to explain it...but basically it limits the traval and keeps the front end lower on uphills giving it a better cg
06-04-2012, 01:27 PM | #9 | |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: got our MRC yesterday....I discovered 2 things.... Quote:
this is how mine is done in the rear the front i couldn't use it as i have a different steering set up that wont work. check out my build it might help Hillbillyrc rockin' it old school | |
06-05-2012, 05:55 AM | #10 |
Thanks for the advice. I've bought some parts today, so I'll get on with modding my mrc as soon as the post arrives! |
06-05-2012, 12:48 PM | #11 |
RCC Addict Join Date: Jan 2010 Location: Dallas
If you are a newb to the MRC and are pulling stuff apart I would highly suggest pulling the trigger on the metal lockers for the front center and rear. They will go soon with weight in the wheels.
06-05-2012, 08:50 PM | #12 |
Rock Stacker Join Date: Feb 2010 Location: Honolulu, Hawaii
| Re: got our MRC yesterday....I discovered 2 things.... best free upgrade check out my free mods! they work sooooo good it should be illegal. no need for aftermarket chassis. |
06-05-2012, 11:26 PM | #13 | |
RCC Addict Join Date: Nov 2007 Location: somewhere
If u just want to limit the articulation just take the ball end off at the bottom of the shock and add some nitro fuel tubing or something similar when u compress the shock the tubing will hit the bottom of the shock body witch in hand will not let the shock shaft go any further up in to the shock body | |
06-06-2012, 05:15 AM | #14 | |
Thanks again for all the info, I feel like I've well and truly hijacked this original thread now, so I'm going to start my own build/noob learnings thread to keep you updated on my progress. | |
