Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: EZRUN motor setup
Old 01-06-2011, 04:19 PM   #1
Default EZRUN motor setup
hey everyone i have a 12t EZRUN motor and esc combo and i have tried every possible combination on the esc to set it up too try and keep the motor from studdering when I'm going slow any advice would be great
http://www.hobbypartz.com/hobbywing-...ess-combo.html
also what size pinion and spur do you guys run/or what is a good size too run
fallin apart is offline   Reply With Quote
Old 01-07-2011, 07:12 AM   #2
i would try gear it down. try running a 12t or 13t pinion. that might help out with the cogging.
CrawlHer is offline   Reply With Quote
Old 01-07-2011, 07:49 PM   #3
Probably won't work, I have only seen sensord motor combos work like the Novak Mongoose or Losi 1/18th Xcelorin Crawler system work in crawlers.
rockslyder is offline   Reply With Quote
Old 01-07-2011, 08:12 PM   #4
trx
I have the same setup,Same thing, Being sensorless is the problem,If by chance you find something that works let me know too. I dont run mine in the crawler mode,seems to work better in the other modes.
trx is offline   Reply With Quote
