01-26-2011, 02:28 PM | #1 |
Rock Stacker Join Date: Jan 2011 Location: Rocklin
| Only have power to the rear
I was out playing in the yard and noticed my losi mini crawler wasn't crawling up anything good. I picked it up and noticed that all tires turn, but under pressure the frontend has no power. What is going on?
01-26-2011, 02:39 PM | #2 |
Sounds like you broke something in the tranny. The spool might be stripped or the slipper might need to be tightened....
01-26-2011, 03:07 PM | #3 |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
Could also be a blown locker. Upgrade to the steel set and crawl away!
01-26-2011, 03:12 PM | #4 |
01-26-2011, 03:14 PM | #5 |
I thought it might be something in the tranny, so I will start tacking it apart, there will be more questions up soon, I have never took a tranny aprt. |
01-26-2011, 04:52 PM | #6 |
Cheap a$$ plastic locker. Mine partially twisted and would catch and then slip. That is what my $$ is on. New MRC?? OOps I guess I need to read more. LOL
01-26-2011, 04:53 PM | #7 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
01-26-2011, 05:08 PM | #8 |
Rock Stacker Join Date: Jan 2010 Location: douglasville
Have you checked to see if the driveshaft has come loose from the output shaft?
01-26-2011, 08:52 PM | #9 |
01-27-2011, 02:35 AM | #10 |
Quarry Creeper Join Date: Sep 2010 Location: Dewsbury, UK
| I guess you mean the output shafts are turning in the gear, did you not ungrade the tranny to metal locker? If not, then metal lockers in the diffs will only transfer the stress to the next weak component (i.e. the tranny diff locker). Once the tranny has metal locker fitted, it all should be pretty tough (to a point obviously!).
01-27-2011, 08:21 AM | #11 | |
Yes I need to go out and find some metal gears and metal locker for the tranny today Quote:
01-28-2011, 04:59 PM | #12 |
Quarry Creeper Join Date: Jul 2008 Location: Sedro Woolley
once you install a metal locker in the tranny you really dont need metal gears. i hva ebeat the dog snot out of mine and no problems.
