Brake torque twist? I have a GC-3 and just put in the Losi brushless and ESC with a 58 tooth spur and a 19 tooth pinion. Wow this thing is fast now. When I let off the throttle and the brakes immediately turn on, the tires all lock and one tire comess off the ground, like the oppsoite of throttle torque twist. Any suggestions on how to fix or limit this from happening? Thanks |
mine does that with a 61 spur and a 12 pinion and a stock motor!!! you have to ask your self are you drag racing? or rock crawling???:roll: if you can turn down the drag brake on the ESC if not add lead to the rear axle |
LOL i am not drag racing it's just sometimes when I have to squeeze the throttle and jump down from a rock the drag brake hits and sometimes flips the truck over. I like the amount of drag brake cuz the truck stays put when it suppose to but I was just currious if there is a different set up or way to tune this from happening.... Maybe I just need to learn better throttle control. |
