1.9 Chassis Measurement Questions 2 Attachment(s) I am having a little trouble figuring out the chassis measurement rules. I get the overall length of the chassis and the wheelbase. Below are my questions. I have also included a picture of what I am working on. It is a departure from a typical look, but I am hoping it meets the rules! Any help will be much appreciated. 1. Is the overall height measured at the tallest point from the skid to the highest point? 2. Does the height measurement have to be in line vertically, or is it from the two parallel lines formed from the two points? 2. Does the 1" cab height need to be right at the windshield or can it be further back on the chassis? 3. Can the 2.5" width be measured anywhere on the chassis? 4. Can the 2.5" width be at the nose and taper back from there? 5. Is the 1" topper height measured from the highest point on the main chassis? This is all I can think of for now, but I may have more questions later. Wes |
Wow, figured I would have had a reply by now. Wes |
No replies must mean I am good to go! ;) Wes |
One last bump, in hope for some help. Wes |
2.1.4 - Bodiless vehicles: Must be a self-supporting, structurally complete, rigid frame. The roof must be raised a minimum of 1” from the main chassis to resemble a cockpit. The frame sides must be an overall minimum of 1” tall (The cockpit & frame side are to be measured vertically from where the hood intersects the cab). Bodiless vehicles should resemble a 1:1 vehicle 2.1.4.1 - Bodiless vehicles must have solid hood panel, solid roof panel and a minimum of 2 solid side-panels 2.1.4.1.7 - Bodiless vehicles must reach a minimum of (A) width, (B) length, and (C) height. Measurements may include, but not limited to bumpers, stingers, frame-rails, side-rails, skid plates, roof, hood, and side panels. http://img198.imageshack.us/img198/4859/captureayd.jpg 2.4.10 – 1.9 Crawler class bodiless 6.75" overall length, 2.5" overall width, and 3.25" overall height. |
I'm not an expert, just trying to help you interpret the rules. 1. Is the overall height measured at the tallest point from the skid to the highest point? According to the diagram in the rules, yes. 2. Does the height measurement have to be in line vertically, or is it from the two parallel lines formed from the two points? According to the diagram, vertically from the lowest to tallest point. 2. Does the 1" cab height need to be right at the windshield or can it be further back on the chassis? 3. Can the 2.5" width be measured anywhere on the chassis? Widest point. 4. Can the 2.5" width be at the nose and taper back from there? According to the diagram in the rules, yes. 5. Is the 1" topper height measured from the highest point on the main chassis? I'm not positive on the topper, but it does say minimum 1". And you will have to have separate hood, roof and body panels to compete, according to the rules. |
Thanks for the help. My overall dimensions are fine, I am just not sure about the topper. The 1" above the cab should be fine as long as it doesn't have to be right at the windshield pillar. The dimension I reached a little bit behind. I am just not sure if I will get grief about my topper being inside instead of outside. Worst case I can make one for the outside, but I like the look. Wes |
Re: 1.9 Chassis Measurement Questions Quote:
http://www.rccrawler.com/forum/rules...asurments.html |
