02-21-2016, 03:01 PM | #1 |
Newbie Join Date: Mar 2013 Location: Manassas
| Beast II rear shaft issue
I haven't seen anyone else with this problem and it's driving me apesh*t. If I fully compress the rear axle/shocks, the drive shaft separates. I've tried trimming multiple axles to different lengths with no luck. Making the female end longer causes it to bind and even if it binds just a little, it still pulls apart. Am I the only one this is happening to? If so, maybe I did the assembly wrong....but I can't find out where. |
02-21-2016, 04:22 PM | #2 |
Rock Crawler Join Date: Nov 2014 Location: Dells
| Re: Beast II rear shaft issue
Mine does this too. IDK if you would be able to get it to pop while driving though.
02-21-2016, 05:12 PM | #3 |
Pops out constantly on rocky terrain.
04-18-2016, 08:15 PM | #4 |
Pebble Pounder Join Date: Mar 2016 Location: Houston
I have the same issue with my rear shaft as well. Any time you actually put torque on it, the thing would pop apart. After some measurements and a bit of research it seems that the shaft size is somewhat common in the 1/14 semi trucks. I found this shaft, its the perfect size off the shelf and best of all the design will literally not let it pop apart. |
05-22-2016, 06:44 PM | #5 |
excellent! thanks!
Beast II rear shaft issue - Similar Threads | ||||
Rear axle short shaft issue? | Katan | Axial Wraith | 216 | 04-24-2017 06:46 AM |
RC4WD Beast II. drive train issue | slm0001 | Multi Axle Rigs | 5 | 12-30-2015 10:04 PM |
Drive Shaft Issue | STEEL_CITY_CRAWLER | Axial AX-10 Scorpion | 3 | 04-01-2010 03:42 PM |
