Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Wheely King 6x6
Old 03-12-2020, 01:05 PM   #1
Default Wheely King 6x6
A new WK axle 6x6 build whit a Mack M123 Alu body build.
Last edited by dzsenci; 03-12-2020 at 02:12 PM. Reason: https://www.photobox.co.uk/my/photo?album_id=5828382241&photo_id=502764619712
dzsenci is offline   Reply With Quote
Old 03-12-2020, 01:13 PM   #2
Moderator
JatoTheRipper's Avatar
Default Re: Wheely King 6x6
We can't see your photos.
Even when clicking the link the message says:
"You cannot access this album
This album is no longer shared with you.
Sign in or Register to discover Photobox"
Old 03-12-2020, 01:26 PM   #3
Moderator
Try this photo hosting site: https://imgur.com/
Old 03-12-2020, 01:57 PM   #4
Old 03-12-2020, 02:04 PM   #5
Old 03-14-2020, 08:09 PM   #6
Location: North to Alaska - go north, the rush is on....
That looks pretty awesome man!!!
AK KRAWLER is offline   Reply With Quote
Old 03-15-2020, 11:06 AM   #7
Holy sh*t that thing is going to weight a ton. But it is a cool build keep up the good progress
big specht is offline   Reply With Quote
Old 03-15-2020, 11:27 AM   #8
Some of the best hand fabrication of parts I have ever seen. Great work on building your own parts the way you want them!
Szczerba is offline   Reply With Quote
Old 03-15-2020, 01:21 PM   #9
Thank you guys. The truck will be around 9 kg with all the details
https://i.imgur.com/qUoxlZU.mp4
Old 03-15-2020, 09:32 PM   #10
Impressive build. I built a Wk 6x6 years ago, and had issues with trans gears stripping and Dogbones breaking. If you plan on driving anything other than mostly flat trails, you might want to carry some spares. Mine weghed in @8lbs or so on 5.4" Proline Tsl's.
lonleycreeper is offline   Reply With Quote
Old 03-15-2020, 09:45 PM   #11
9kgs is not that bad for a large rc custom build truck. I have one 6x6 that is 9kg and a tow truck that is 9.5 kg that pulls a 13.6 kg trailer plus humans! haha I just run a 1200kv brushless motor and 4S lipo with the correct gear reduction.
Again, great build here. Ready for the full build pictures.
Old 03-16-2020, 02:58 AM   #12
I run on 3s whit a 21T brushead motor. Not to doo to much damage i put on a Blitz sliper clutch a CK gearbox and now 88 spur whit 31 pinion.
Sent from my INE-LX2 using Tapatalk
Old 03-16-2020, 07:10 AM   #13
Moderator
Awesome work! I love the working hood latch. Great fabrication skills.
Old 03-16-2020, 10:43 AM   #14
Any other reduction?
I ran a 96, 14 combo and barely kept the heat under control with a 35 540 motor.
Old 03-16-2020, 11:34 AM   #15
It is the WK gearbox whit a CK reduction box spur 88 pinion 31 motor 27T, and it's ok, and i use a diy transfer case whit 3 robitronic 21 mod 1 pinions
Old 03-16-2020, 12:44 PM   #16
And here is the fuel tank holdings and the fuel tank
Old 03-30-2020, 11:15 AM   #17
Doing some stuffs
Old 03-30-2020, 11:28 AM   #18
Moderator
That body is so awesome!
Old 03-30-2020, 11:31 AM   #19
I'm thinking of making dors for the body.....what do you think
Old 03-30-2020, 11:58 AM   #20
Moderator
I don't think you even need opening doors, but an interior would be cool.
