03-31-2008, 07:27 PM | #1 |
Newbie Join Date: Feb 2007 Location: Earth
| Amp draw?
Noticed that when I gave my truck small inputs of throttle the motor would strain and I'd need to give it more throttle for it to move.. So I took the motor out and slowly gave it throttle. Turns out with small amounts of throttle it wouldn't spin, it needed more to start up. This was with a 2/3A size pack(6 cell, like the ones that go in 18th scale cars) so I was wondering if maybe the batteries are having problems supplying enough amps. I hooked up a normal sized pack and it seemed to lessen the problem, couldn't really tell. Is it possible I need to upgrade batteries to supply more amps?
03-31-2008, 07:56 PM | #2 |
Rock Stacker Join Date: Mar 2008 Location: Arvada
what is your settup esc,motor, batts charger servos. etc.
03-31-2008, 08:03 PM | #3 |
2/3 batts have plenty of amps , check to make sure every thing is set up correctly, battery fully charged, radio-esc, set up no binding in tranny/axles, sounds like you could you may have one of theses props
04-01-2008, 06:29 AM | #4 |
Okay, I'll double-check everything. I rolled the chassis before and it didn't bind, so it must be something else. Thanks
