New To Crawlers Hello everyone, thought I would say hi. I am getting my first crawler on saturday(axial)any words of wisdom would be greatly appreciated. I am looking foward to meeting and cralwing with the members here in AZ.:) |
Which Axial are you getting? My advice if you're getting the kits: > Take your time building it. It's a fun, easy build and slow work is usually careful work. Just don't rush it. > Hack off the fenders front and rear and slam the body. > Run the travel limits inside the shocks (under the piston), not outside the shocks the way the instructions show. > Cut the foams in a star shape and add about 4 to 6 oz. of stick-on lead weight to the front tires. I really like the following upgrades: > RCP aluminum knuckles > MIP or Axial universals axles > Losi, Panther or Pro-Line tires > Axial upper link tray > Axial servo/battery mount > TCS Boomerang rear upper link mount |
Save your foams and get some nice Memory Foams.. First things first. Buy nice Electronics. Castle ECS (Mamba Max or Sidewinder) Servo with over 200oz of Torque, and a Dx3R would be nice. Get a Nice handwound Brushed Motor. Then upgrade from there. Replace things as you go. Get a fill for your crawler and learn to drive it. You will better off that way. |
The best advice I can give you is to use the search function on the forums and you will find a wealth of information (and also a wealth of B.S.sometimes).;-) |
hey Violent, just got into crawlers here too. so far i like th axial, but its my only experiance with crawlers so far. |
