Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Rock Lidards vs Rock Crushers
Old 07-11-2008, 11:08 PM   #1
Default Rock Lidards vs Rock Crushers
Does anyone now if rock crushers are better that rock lizards?
polaris98 is offline   Reply With Quote
Old 07-11-2008, 11:30 PM   #2
Debunking old stereotypes
freetimecrawler's Avatar
You failed to mention better at what?
Rock Crushers are a scale tire, Rock Lizards are what comes with the Axial AX10, and are supposed to be a comp tire. IMO neither are comp tires, and the Crushers make the better scale tire.
freetimecrawler is offline   Reply With Quote
Old 07-12-2008, 05:38 AM   #3
The Rock Crusher tires are probably the most realistic tire available, but the Rock Lizards crawl better. If you're buying tires and want the best performing possible, I wouldn't consider either. If you want tires that look very real, go with the Crsushers. If you are buying an Axial truck, I wouldn't be in a huge rush to change the Rock Lizards. They do fine for crawling around.
MattH is offline   Reply With Quote
Old 07-12-2008, 03:05 PM   #4
the rock lizards work awsome as a couch crawler tire. anywhere else they suck for me
wojin is offline   Reply With Quote
Old 07-12-2008, 03:16 PM   #5
666
MODERHATER™
666's Avatar
Rock Crushers smell better.
666 is offline   Reply With Quote
Old 07-12-2008, 03:46 PM   #6
ANYTHING smells better!!
FL Knifemaker is offline   Reply With Quote
Old 07-12-2008, 10:26 PM   #7
lizards hold more water though
ADDICT is offline   Reply With Quote
Old 07-13-2008, 12:16 AM   #8
Which tire is better at rockcrawling?
Old 07-13-2008, 12:19 AM   #9
Panther Cougars, or Losi Claws.
Old 07-13-2008, 06:21 PM   #10
go w/ rock claws
NeXt559 is offline   Reply With Quote
Old 07-13-2008, 06:43 PM   #11
just had the lizards on the rocks for the first time, they had no problems. if other tires are really that much better, i cant wait to get new ones
