Is this enough or do i have to reorder (AX-10) Hi guys, my first post, hopefully its not my last :). I decided to go for the AX-10 car. I have ordred some stuff for it (it will be a formulaoffroader later) Did read somewhere that driveshafts and knuckles could be a good upgrade.. i went for MIP thru the whole car, Slipper and Losis Crawler shock-kit. Alloy steering knuckles, and some upper links in alu to,some CF parts like chassi sides (just for the look, and servo + batt mounts...) Widening kit, And now the servo Q, i have a few here to choose at home. ACE1015 14.5kg ACE1313 6 or 8kg Ko 2413 app 6kg What i have understand, the best thing is to mount the batteries on the fr/rear axles..for lowering the CG? i wil use 4400mah 2s Lipo in this car (saddle) that shouldnt be any problem ? i know "search and you will find", but this is a new class, and i do not know what to search after, any small tips, that is a MUST for this car to upgrade ? let me know, best R Thomas |
Thomas, I'd run the ACE 1015. A lot of guys run those in buggies and truggies so it should hold up fine. I tend to go over board when it comes to servos, so I would personally recommend going with one that dishes out the most torque you can find. Oh, and get those aluminum knuckles. RCP Crawlers' high clearance knuckles will work great with your MIP CVD axles. You'll have tons of turning. Good luck and have fun. I went to Sweden a few years ago--pretty country and real nice people. |
Welcome and you will enjoy your AX-10..."thumbsup" 1/18 scale lipo packs work awesome in the AX-10 You will want to lower the stance of the stock crawler.... Try to get the links level....(move the shock limiters to the inside of the shock) Next get some soft springs in the rear shocks... slam your body down low as well..... Try to get all the weight down low....the lower the cog the better it will climb...... You definitely want to weight the wheels....and get some tires w better grip. You should check out Mayhem Engineering in the vendors section. He makes a wheel called a double phatty that uses Ball bearings for rotating weight that settles when stopped....(check em out..."thumbsup") We are enjoying our axials and Im sure you will too... berm |
Hi Berm, and thanks for the warm welcome..il check this out..asap the stuff arrives...cant bearly wait for it :) |
get some lead 1/4 ounce weights from your local tire shop or a store like tcscrawlers.com or ckrccrawlers.com and stick them on to the inside of your wheels. take your beadlocks off remove your tire and foam and stick them onto the center of the wheel. |
WOunder if they can handle the rpm´s later? |
ive tested the car in the air only...all shrinktube will be redone Red will be black, all yellow straps will be black...maybe a test drive tomorow http://i123.photobucket.com/albums/o...d/DSC_0034.jpg http://i123.photobucket.com/albums/o...d/DSC_0035.jpg http://i123.photobucket.com/albums/o...d/DSC_0036.jpg http://i123.photobucket.com/albums/o...d/DSC_0037.jpg http://i123.photobucket.com/albums/o...d/DSC_0039.jpg http://i123.photobucket.com/albums/o...d/DSC_0040.jpg http://i123.photobucket.com/albums/o...d/DSC_0041.jpg |
i can tell you right now be prepaired to break the transmission. i have the same setup (but with a 11,400kv motor) and i break all kinds of stuff. |
YEs it is ACE1015 known from now on as XP servos from AE crawler4lif3:What will be broken, can ya be more specefic please :) |
If you're really going to be running those paddle tires you might want to reconsider the weight issue. You might also want to specify that it's not going to be a crawler so as to not get bad advice. |
here in mine http://i154.photobucket.com/albums/s...2/IMG_0212.jpg http://i154.photobucket.com/albums/s...2/IMG_0205.jpg and my outputs http://i154.photobucket.com/albums/s...2/IMG_0236.jpg and yea its broken in the pic. have fun"thumbsup""thumbsup" |
ANy links for thoose parts m8, seems like i need to order them if this will be an issiue..i mean, i wont just stand still :D so everything need to get this almost rocksollid ..fixed a heatzink and a fan mount on my car now, it did get hot, but not to bad, ran 3600 mah and thats it, more and i have propably rosted the motor :D...il stick to the Pinion to se if my heat has dropped down a little... ok i serached little.. http://rc4wdstore.com/product_info.p...roducts_id=805 this one ? i did find some "straight axles...will this widened the truck, or stock width ? |
yea those are them, if you get those they will never break. the straight axles will not widen the truck but will be stronger. if you wanna widen it you need wheel wideners or a different offset wheel. |
Thank you so much C4life, il order it asap |
man that thing looks like so much fun! i might have to buy another one just to do this to it! we have lots of sand here bein on the coast! that thing would be a blast! post up some vids for us! later guys |
You where right... 4 packs then it died... http://i123.photobucket.com/albums/o...d/DSC_0129.jpg http://i123.photobucket.com/albums/o...d/DSC_0130.jpg http://i123.photobucket.com/albums/o...d/DSC_0131.jpg will order the rc4wd steel one first in the morning... |
