Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: help with xtrail chassis
Old 08-13-2008, 08:35 PM   #1
Default help with xtrail chassis
i was just wondering if this was corret or not with the droop shock setup and stuff its kinda hard to get articulation with the droop style but idk just let me know or if u know anything else u can see in the pics also if u want more pics or better ones let me know thanks for the help bc i wanna get it done www.photobucket.com/larryt
saturnsl89 is offline   Reply With Quote
Old 08-14-2008, 10:37 AM   #2
When I built mine, it had way too much articulation, so something is up with yours if it isn't flexing like made. BTW, lots of articulation is very bad. Look for what's binding as the suspension moves. I don't have mine in front of me right now and it's hard to tell from your photos, but I would look at the lower shock mounts and the upper link fram mounts. I would space the lower shock mounts so the shock don't bind during flex and move the upper link mounting points out (i.e. use different holes). I hope this helps.
MattH is offline   Reply With Quote
