Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Diff locks on ax 10 rtr
Old 01-03-2009, 12:14 AM   #1
Default Diff locks on ax 10 rtr
Hi do you lock the diffs on the ax 10 rtr by using the heavy duty locker or is there another way you do it and if you use the heavy duty lockers do you use them in the front and back axles or only on the front?Thanks
AXE 10 is offline   Reply With Quote
Old 01-03-2009, 01:39 AM   #2
hi you only have one locker that came with rtr. the back axles is already locked. you have to put the one in the front axles.
Bugspeed is offline   Reply With Quote
Old 01-03-2009, 01:42 PM   #3
Thanks for the help.
