04-21-2009, 01:34 PM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: Indianapolis Indiana
| which is better out of the box between these crawlers
OUT OF THE BOX ax10 scorpion rtr (with front locker in etc) cliff climber wheelyking with lockers and do you guys thing the mrc price will go down anytime soon? |
04-21-2009, 02:18 PM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Tucson, AZ
wow really... another which ones better.. Use your search button and you will find your answer quickly. Ax10 is the obvious choice, and then there is the venom creeper if you dare to be differant. What I've done to mine makes it every bit as competitive as an ax10. Are you wanting function over form? Do you think you will want to comp your truck? Or do you think you will just use it as a backyard crawler?
04-21-2009, 02:32 PM | #3 |
get any form of the ax-10 and it will beat the cliff climber no problem i know because i have driven both and the wheely king is set up for bashing get the ax-10 i think it is one of the most starter friendly and comp. friendly for stater rigs out there and they will last a lot longer i have had my ax-10 for close to a year and it still has the orignial gears, axles, tranny, links, and a few other things and i use it just about every day and only the rain keeps me from driving it.
04-21-2009, 06:01 PM | #4 |
i want crawling capability but no comps. im going to try to find a used ax10 around here/rcu
04-21-2009, 08:25 PM | #5 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| Sure
I would go with the Ax10, because it has alot more support. There are tons of parts and numerous people with advice on the Ax10. I can remember when I just wanted one to crawl around my yard with, but things quickly changed when I went to my first comp. I wanted to test my rig against other drivers, and so the addiction began. Make the right choice and buy the Ax10. |
04-21-2009, 09:21 PM | #6 |
Rock Crawler Join Date: Apr 2008 Location: Lexington
AX-10 hands down. |
04-21-2009, 09:58 PM | #7 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
X10000000000 for the AX10. I have had both the Wheelyking and the Ax10 ARTR. Tho I liked the wider stance of the WK it took """"""ALOT"""""" of work to make it crawlable. My Axial was basically add some wheight and soft front springs and crawl circles around my highly modified king. Of course the axial is HIGHLY modded now as well.
04-22-2009, 12:26 AM | #8 |
Pebble Pounder Join Date: Dec 2006 Location: da big island, HI
id go wit the ax10 its a great start with out doing to much upgrades right out of the box |
