07-05-2009, 01:06 PM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: buford ga
| gearing and dig
I need to know what i should use on my berg axles i am using 45 t motors i need size of gear number of teeth and pinon all the stuff like that and also how do i wire up the dig on my berg i am using 2 dig switches and a kk dig plate a traxxas tq3 radio |
07-05-2009, 01:34 PM | #2 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
Post all your questions in your thread... delete this one so you arent pissing people off like you do on RCA. My berg 2.2 build You might find your pinion answer in your own thread. and SEARCH |
07-05-2009, 02:05 PM | #3 |
Rock Crawler Join Date: Dec 2007 Location: T1E Country
13t or 14t 48p metric what kind of battery? |
07-05-2009, 02:42 PM | #4 |
its a 14t with sidewinder esc and 1350 mah 11.1 volt bat
07-05-2009, 03:06 PM | #5 |
Quarry Creeper Join Date: Aug 2008 Location: in the basement cussing my broke ass rig
If you can afford it, i would highly recommend a Punk RC dig switch. The micro switches don't always hold up that well under high current situation(motor binding and such). I saw a few days ago he had some scratch and dent selling for $20 less than normal. They may be gone by now... But if money is an issue and you must use the switches, wire them on the negative wire. Into the switch on C and out to the motor on NC so that when your servo activates the switch it opens the circuit killing that motor. Good luck...
