11-20-2005, 02:54 AM | #1 |
Newbie Join Date: Nov 2005 Location: Kearney
| Electrical problems
I will start with I NEED HELP i have a super rooser with a traxxas controller and receiever running a super rooster and i am having a problem with my truck. What is happening is when i drive it around the living room (i just built it like 3 days ago) when i steer all the way to one side of the steering servo which is a hitec 645 the rooster looses power by that i mean if i am driving and i turn it all the way to one side the truck acts like it looses power i can't figure it out i have tried different radios and recievers and i can't seem to beat it i need some assistance this might be an easy question but i am new and i am getting very discuraged with this problem so any help i would appreciat greatly thanks j |
11-20-2005, 07:40 AM | #2 |
Rock Stacker Join Date: Jul 2005 Location: williamsburg, Va.
you could try if your radio has it, turn down your steering limiter. it sounds like you either have a bad servo that is shorting when turned to full tilt. i have never had this happen to myself but my friends maxx did it. or mabey just mabey your tire is getting hung up on your chassi some place??
11-20-2005, 12:05 PM | #3 |
It happens if you turn one way, or both ways? It loses a lot of power, or just a small amount? |
11-20-2005, 10:24 PM | #4 |
| It is kind of sparatic but it usually is only when i turn one way and i know it has to do with the steering servo because while i was checking it i had the wheels cranked one way and i lost power so i unplugged the servo and the truck started working but i am a little pissed cause the servo is brand new probably only been on the truck for 3 days probably 1 hour of run time has anyone had this problem before and how do u go at getting it fixed i just am not sure if it is the servo or something else?????? |
11-20-2005, 11:27 PM | #5 |
I joined the Band! Join Date: Sep 2005 Location: Tampa
its a short take the servo back and get another...
