Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: What makes a esc stop?
Old 10-21-2009, 03:09 PM   #1
Default What makes a esc stop?
I have a MOA and my truck just stops running after a while. I have come to the conclusion with some help from here that I need a new esc but want to make sure the one I get will be good for my motors. What causes it to stop? Amp overload? Overheating? Not sure. Thanks
Talon
gunch is offline   Reply With Quote
Old 10-21-2009, 03:11 PM   #2
robmob's Avatar
Usually it's heat that causes it to shut itself down.
What ESC, battery and motors are you using?
robmob is offline   Reply With Quote
Old 10-21-2009, 04:19 PM   #3
I've got a far from stock cliff climber with stock esc, banebot 390's and (2) venom 6cells. It runs fine on flat ground but as soon as I hit the rocks it stops.
Old 10-21-2009, 04:27 PM   #4
I'm sure those motors are too much for the stock ESC.
Another thing that will do it is a servo that draws more current than the BEC can provide.
microgoat is offline   Reply With Quote
