10-31-2009, 03:50 PM | #1 |
Newbie Join Date: Oct 2009 Location: Oneida
| axle wrap
I just picked up a clod based crawler. it has a 4 link but also has serious axle wrap. is this normal?
10-31-2009, 03:55 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
if your useing axle wrap in the right terms (pinion points up under throttle) you need to check and replace the link ends, a link suspention shouldnt have axle wrap at all
10-31-2009, 04:11 PM | #3 |
yes the pinion location moves. I believe the upper links are mounted to hi. I will try to post a pic. My shocks may be to long also. |
10-31-2009, 04:14 PM | #4 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
woah yeah, those upper links are WAAAAY to high. Can you get them level with the ground? That usually works best on most trucks. |
10-31-2009, 04:17 PM | #5 |
x 2 WAY to high, they should be mounted down by the top of the lower triangle wholes in the side plates, or somewhere in that area
10-31-2009, 04:18 PM | #6 |
I am a newbie, so don;t flame. what is the best way to fix this. shorter shocks?
10-31-2009, 04:22 PM | #7 |
Thanks I will lower the upper link mounts. So you think I need shorter shocks also or will just repositioning the upper mounts fix the prob?
10-31-2009, 04:22 PM | #8 |
lower your upper link mounting location. the upper links should run paralell to the ground roughly, give or take a few degrees
10-31-2009, 04:25 PM | #9 |
hey guys, thanks for the help. - the guy that had it before me took out the foam from the tires. do I need ant foam?
10-31-2009, 04:26 PM | #10 | |
How much flex does it have? If it's too flexible or too tall, shorter shocks could help with both. | |
10-31-2009, 04:30 PM | #11 | |
obviously the guy that had it before me set the links up wrong. He also had spacers on the shocks. Are these normal? sorry for the basic questions but ya gotta learn somehow. I want to have a decent crawler, just something to play around in the back yard with (for now). Last edited by Cloddoctor; 10-31-2009 at 04:34 PM. | |
10-31-2009, 04:30 PM | #12 | |
With no foam the tires usually won't have enough support, and without an air hole, they're usually too bouncy. | |
10-31-2009, 04:34 PM | #13 | |
What are your plans for it? | |
10-31-2009, 04:41 PM | #14 |
My friend got me into this and I will prob go crazy with it now but I just want hang with his crawler when we go. I just want a good reliable machine. I already broke a wire off of the motor cause of the axle wrap. So I gotta fix all the little bugs. If anyone has any suggestions how to make it more reliable I am open to all kinds of ideas. Also the tires conform well and do have breather holes. I will try some foam and see which works better. I got the rig for $150, so I hope I didn't get taken.
