Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: kits?
Old 11-05-2009, 09:29 PM   #1
Default kits?
I know both the axial models come in kits, are there any other crawlers that come in kits that need to be assembled?
nstn8 is offline   Reply With Quote
Old 11-05-2009, 09:46 PM   #2
Venom Creeper
BLKXJ 96 is offline   Reply With Quote
Old 11-05-2009, 11:46 PM   #3
Or you can do like ALOT of us do is buy axles and a transmission etc etc etc and build your own truck from the ground up. Its the way I like to build my crawlers . Axial sells axles and transmission separately. Skys the limit if you wanna build a crawler and you meet alot of people on the awesome forum.
dirttrackdemon93 is offline   Reply With Quote
Old 11-06-2009, 07:05 AM   #4
S ARR T 8's Avatar
Yeah I second that I just orderd a creeper kit but the more time I spend on here I kind of wish I would have just built my own from all diff parts.Check out some of the rides on here there is some really cool thing you can do sky or should I say $ the limit.
S ARR T 8 is offline   Reply With Quote
Old 11-06-2009, 07:29 AM   #5
Tamiya has a kit for 3 different types of vehicles that are on the CC-01 chassis.
BadRockNoCookie is offline   Reply With Quote
Old 11-06-2009, 08:11 AM   #6
This sounds like a good idea, but seems like it will get expensive real fast... axles are 35-40 a piece, 35-40 for a trans, 50 for beadlocks, 35-40 for tires. I'm already up to 160 and I don't have any of the pieces to connect it all together... does that stuff end up cheap? or am I missing something here?
Also I am not against this idea... it sounds like a lot of fun, is there a thread here where this has kind of been laid out a little bit for the first time crawler? I mean when your end product is crawling I guess it's okay to crawl to get there
Old 11-06-2009, 08:32 AM   #7
On the lookout for Rocks
constantmotion's Avatar
Just get the AX-10 kit from RPP. It's $199 and you only have to get your electronics. This will be the best option to get you going if your wanting to go the kit route.
constantmotion is offline   Reply With Quote
