01-15-2010, 01:51 AM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: KK Sabah North Borneo
| Parallel or Series MOA Wiring?
I've seen & heard it somewhere that I should rewire my MOA with parallel wiring. Do you all mean from the ESC, + & - wires go to the rear motor +ve & - posts AND THEN FROM this rear motor, +ve & - wire go direct to the FRONT MOTOR - & +ve (need to do opposite rite)... is that correct? For now, the stock wiring is from ESC, two sets of +ve & - wires, red & black go direct to front and rear motor. is this not ok? Why? So far if u ask, i noticed when climbing esp, the rear stops and the front keep crawling(nope, i dont have front dig)... and sometimes, if the front already reach the top, the front motor stops and the rear just keep turning.... is this what u all call "STALL"? if so, what the parallel do then? avoid this "STALL" thing? I'm so newbie... pls explain.. thanks. |
01-15-2010, 02:25 AM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Buy another ESC so you have 2 ESC's and make it easy! Or just buy a Punk RC dig unit and you will be set up right daddy-0! You can pick up a Punk unit used for about $50 in the FS forum |
01-15-2010, 02:33 AM | #3 |
Here this should help if you don't want the other options....The top pict is Parallel, the bottom is series.
01-15-2010, 02:58 AM | #4 | ||
interesting... will a normal 3ch radio like mine the ko propo helios be able to use the 2 ESC setup? I heard the punkrc for dig... but i dont think my current can use it... [this actually for dig question :-P ] and if the 2 esc, does it have to be of the same brand/type or can it be mixed of other brands? Wiring diagram? Quote:
that's what my current ESC Set up. hmmmm.... but how come it still can stall? I thought with the above parallel wiring, the power will be the same to front and rear... but it seems it goes to the less load.. which we want to avoid right. correct me if im wrong | ||
01-15-2010, 03:12 AM | #5 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
Here this might help dude 2 ESC wiring Good luck Bud |
01-15-2010, 03:33 AM | #6 | |
from the top pic.. i can see that 2 ESC can be controlled with normal 3ch radio like mine... but i guess must be with the same ESC type/brand so not to mess with the electrical stuff setting. ok got it. the bottom pic is for setting the front & rear dig right. ok got it. now its a matter of heating the solder gun and finger crossed everything works as they meant to be Thanks Saxton | |
01-15-2010, 03:39 AM | #7 |
Your very welcome bud Good luck |
01-15-2010, 11:24 AM | #8 |
Or just buy a Punk dig and make it easy for your self like I said. You will only need 1 ESC and you will have front and rear dig! |
01-15-2010, 05:21 PM | #9 | |
maybe u missed this... but i never asked for DIG setup moreover, my radio, ko propo helios dont have this 3 position 3channel.. so punkrc dig is no use to me... not yet at least till i change to dx3r. im still curious with the parallel n series wiring... the stall thing... maybe just live with it...MOA | |
01-16-2010, 12:20 PM | #10 |
Wow, anyone thought of making this one a sticky? This is pretty much a down-and-dirty on newby MOA wiring.
01-16-2010, 05:41 PM | #11 |
Pebble Pounder Join Date: Dec 2009 Location: Bettendorf
| Novak
I hear Novak has a new ESC coming out that runs two motors and has built in DIG. I think it's like 160$. Sounds pretty sweet though.
01-22-2010, 08:23 PM | #12 |
Rock Stacker Join Date: Jan 2010 Location: Bonney Lake
sorry if this is a newb question but isnt the parralel wiring mod a cheap version of the dig? couldnt really figure out if it was or not by what was stated in this thread...
01-22-2010, 08:39 PM | #13 | |
hmm from my understanding.. the parallel wiring is nothing to do with the dig.. at least to the term of "dig" itself. but from what i gathered reading from this awesome forum, all MOA crawlers with the single esc just could not escape from the "motor stall" thing.. especially to the rear motor. no matter what or how u wired it. there's remedy.. like the different pinion between front and rear motor - which i have not tested yet ... but read somewhere in the forum. the stalling of the motor, or how i understood it, the motor stop from moving, can be an advantage when climbing steep trail.. the rear motor just STOP moving or stop turning while only the front motor keep turning, trying to get a grip.. yep.. this moment of time i did see it live while i tried to climb a 60 degree plywood set up at home. in this case, no dig is needed.. it just happen. the rear motor just stop. so kind of cool though. I heard, with this parallel wiring, it helps in the power distribution... i am not so sure in this thing.. others know better, pls elaborate on this. thanks in advance. | |
03-31-2010, 02:35 PM | #14 |
Rock Stacker Join Date: Mar 2010 Location: Dallas NC
| Need a little help wireing dual stock ESC's
I am going to wire in another stock esc to run dual esc's and I have been looking at this diagram and have a couple quistions please help. I need to know if I need to splice all the wires together by color that plug into the receiver? Also there are four motor wires on each ESC (blue and yellow) do i splice the yelows together and blues together for one ESC and plug them to a motor and the same to the other? Please let me know and please elaborate thank you. |
03-31-2010, 02:58 PM | #15 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
in that picture it appears they are spliced and going into the same port but i'm pretty sure if your running dual esc's you'll want a 4ch radio such as the 4pk or a stick radio.
03-31-2010, 08:07 PM | #16 | |
04-01-2010, 08:03 AM | #17 |
This link might help you Jonehrc duel ESC quistions |
04-01-2010, 10:40 AM | #18 | |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
there is one way to help "Clod Stall". When you wire you two motors from your esc, first take your + - from esc, solder to the rear motor (first). Then cut 2 wires and solder them onto your rear motor then run them up to the front motor. There is a difference in doing this, it's still parrallel. Think of the path of the energy starts at the speedo down the the rear motor (First) than up to the front motor. You want the power to arrive at the rear first helping in clod stall. And by wiring it my way it allows you to have rear dig (rear lock) by a simple toggle switch you have to mount on your truck to cut power. A small micro servo will be required to "toggle" the toggle switch. That only requires 2 position switch. But It won't fully lock in a bind this will still allow your motor to break loose with enough traction. I just make my rear motor mesh very tight to help some. Last edited by Blood_Clod; 04-01-2010 at 10:45 AM. | |
