02-12-2010, 04:47 PM | #1 |
Newbie Join Date: Feb 2010 Location: torrington
| four wheel steer? haters welcome!
i have a venom creeper to start off. i do not want to run a dig unit. im running a 3 channel radio and receiver. c1 is steering. c2 is throtle. and three is a on/off switch. any ideas on how to run it with the on off switch? i dont care if its not a good idea its just something to try. more of a wow factor haha |
02-12-2010, 05:51 PM | #2 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
if your 3rd channel is only a 2 position switch your kind of SOL in the independent control of rear steer. If its a TQ3 or MX3 or another radio that can be modded for a 3 POS switch then after a little soldering it wouldn't be difficult at all. But if you ever decide to compete you will need to lock it out or remove it to be legal. |
02-12-2010, 06:17 PM | #3 |
You could also get a Y connector, but you'd be steering both ends at the same time.
02-12-2010, 07:51 PM | #4 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
y connector with a pico switch, you could have 4 wheel steer on or off.
02-12-2010, 07:52 PM | #5 |
| what kinda switch? and would it work in the 3rd slot?
02-12-2010, 08:00 PM | #6 |
yeah youd run the Y-harness through the switch, guess youd have to make sure your rear wheels where centered before you turned it off http://www.dimensionengineering.com/PicoSwitch.htm Personally I have my light setup running off a toggle switch, with a micro servo switching it on or off. pico switch would be easier though and they are cheap |
02-12-2010, 08:07 PM | #7 |
so i would basicly run the two power wires to this and the ground to whatever. im running a traxxis receiver and controller for the time being so im trying to run it off of the thumb switch. and when i get my new stuff in running it off of that. and would it be better to run a 4 or even 5 channel setup before i buy anything
02-12-2010, 08:11 PM | #8 | |
02-12-2010, 08:14 PM | #9 | |
02-12-2010, 08:52 PM | #10 |
oh man thats kinda dope. but would it kill the battery faster.
02-12-2010, 11:11 PM | #11 |
02-13-2010, 11:00 AM | #12 |
Quarry Creeper Join Date: Jan 2009 Location: longwood, fl
If you have a tq3 radio take out the red thumb switch, go to radio shack and get a toggle switch but make sure you get one that always returns to center, wire it up and good to go.
