Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Newbie CC BEC wiring question
Old 04-02-2010, 07:35 AM   #1
Default Newbie CC BEC wiring question
Seems like a silly question, but I can't find the answer. In the CC wiring diagram I can't tell where to plug the connector into the receiver. I have a Futaba R603FF receiver that has four inputs - steering, throttle, 3rd channel dig, and B/C (labeled Power Connector/DSC connector). I'm assuming it goes into the B/C input, but want to be sure - don't want to experiment and fry some expensive electronics. Thanks.
new2it is offline   Reply With Quote
Old 04-02-2010, 07:51 AM   #2
Yep.
3: Dig
2: ESC/throttle
1: Steering
B/C: BEC
silentcircus is offline   Reply With Quote
Old 04-02-2010, 08:07 AM   #3
Thanks. Wanted to make sure. Rather ask the question than burn up some electronics!
Old 04-02-2010, 08:16 AM   #4
Definitely!
Old 04-02-2010, 08:41 AM   #5
Hmm... just set it all up and have no steering. CC BEC light is green. Cut the red wire from the esc to receiver. No power to steering servo. Throttle and Punk dig work perfectly. Any thoughts?
Old 04-02-2010, 09:54 AM   #6
sure u got the bed plufed into the rx the right way? if its in backwards it woint work
ultimate_monkey is offline   Reply With Quote
Old 04-02-2010, 12:13 PM   #7
On the lookout for Rocks
constantmotion's Avatar
yeah....check the polarity on the steering servo plug.
constantmotion is offline   Reply With Quote
Old 04-02-2010, 03:25 PM   #8
That did it. Steering plug was in the wrong way. Thx.
