Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: tcs x trail
Old 06-19-2010, 03:26 AM   #1
I joined the Band!
Default tcs x trail
ok as the title says i have one. back hoops cut. but im running tlt axles and unknown tranny. could you guys tell me the best setup for this please.by the way i have axail bent links in the fron and scx 10 straight in the back. goin for a scale look if possible.
p.s. if this isnt the right place sorry
pics are very helpfull
crawlinnTN is offline   Reply With Quote
Old 06-19-2010, 07:18 AM   #2
Suspension-wise, droop is best unless you have brackets made to raise the shocks up a lit.
I think 4-link works best on the rear, when crawling you don't notice how much a 3-link has a rear-axel steer when turning and articulating, but at higher speeds that is magnified.
You want most of your weight between your tranny and front axel.
Give us some pictures so we can see what you have...
Greatscott is offline   Reply With Quote
Old 06-19-2010, 03:12 PM   #3
I joined the Band!
no camera is broke so pics are a cant do sorry
Old 06-20-2010, 05:39 AM   #4
you can always make shock mounts out of scrape metal. 4 link rear and 3 link up front like previously said and you will be golden. I would run the bent links in the back though.
Mr. Ed is offline   Reply With Quote
