plezz help will they fit? Will integy's alloy 8h wheels fit on a scx 10? part # c22793 thanks sorry it was in the wrong spot! |
That wheel is for a Tamiya. If you remove the hex off the SCX10 they should work. That wheel uses the pin on the axle that holds your hex now. I don't know what the offset will be though. If I remember right that wheel comes with several different offsets so you can get the offset you want. I would suggest going with one of the vendors on here and getting a good set of bead locks. With the wheel your looking at you will need to glue your tires if you don't want them to slip. Go with a vendor on here daddy-0"thumbsup" |
Thanks much! |
